Build failure for RTEMS 4.9 / m68k
Andreas Wollschläger
Andreas.Wollschlaeger at e-senza.de
Mon Oct 20 10:55:00 UTC 2008
Hi folks,
I just tried (consider me an RTEMS newbie...) to compile RTEMS 4.9 and the appropriate toolchain as described in the "Getting Started" guide.
Alas, the build fails with some mysterious (to me) error:
gmake[5]: Entering directory `/var/src/RTEMS/build/m68k-rtems4.9/c/mcf52235/test suites/samples/fileio'
m68k-rtems4.9-gcc -B../../../../../mcf52235/lib/ -specs bsp_specs -qrtems -DPACK AGE_NAME=\"rtems-c-src-tests-samples\" -DPACKAGE_TARNAME=\"rtems-c-src-tests-sam ples\" -DPACKAGE_VERSION=\"4.9.0\" -DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.9.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DH AVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -I. -I../../../../../../../ rtems-4.9.0/c/src/../../testsuites/samples/fileio -mcpu=52235 -O2 -g -fomit- frame-pointer -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../../../../ ../../rtems-4.9.0/c/src/../../testsuites/samples/fileio/init.c
mv -f .deps/init.Tpo .deps/init.Po
m68k-rtems4.9-gcc -B../../../../../mcf52235/lib/ -specs bsp_specs -qrtems -mcpu= 52235 -O2 -g -fomit-frame-pointer -mcpu=52235 -o fileio.exe init.o ../../.. /../../mcf52235/lib/no-barrier.rel ../../../../../mcf52235/lib/no-dpmem.rel ../. ./../../../mcf52235/lib/no-event.rel ../../../../../mcf52235/lib/no-mp.rel ../.. /../../../mcf52235/lib/no-part.rel ../../../../../mcf52235/lib/no-region.rel ../ ../../../../mcf52235/lib/no-signal.rel ../../../../../mcf52235/lib/no-timer.rel ../../../../../mcf52235/lib/no-rtmon.rel ../../../../../mcf52235/lib/no-ext.rel
/opt/rtems-4.9/lib/gcc/m68k-rtems4.9/4.3.2/../../../../m68k-rtems4.9/bin/ld: reg ion flash is full (fileio.exe section .text)
/opt/rtems-4.9/lib/gcc/m68k-rtems4.9/4.3.2/../../../../m68k-rtems4.9/bin/ld: reg ion sram is full (fileio.exe section .bss)
/opt/rtems-4.9/lib/gcc/m68k-rtems4.9/4.3.2/../../../../m68k-rtems4.9/bin/ld: war ning: dot moved backwards before `.stack'
collect2: ld returned 1 exit status
gmake[5]: *** [fileio.exe] Error 1
gmake[5]: Leaving directory `/var/src/RTEMS/build/m68k-rtems4.9/c/mcf52235/tests uites/samples/fileio'
The toolchain in use is....
- Binutils 2.18 for target "m68k-rtems4.9"
Applied patch was binutils-2.18-rtems4.9-20080211.diff
- GCC 4.3.2 with newlib 1.16.0
Applied patches were gcc-core-4.3.2-rtems4.9-20080828.diff and newlib-1.16.0-rtems4.9-20080827.diff
Any ideas ?
Cheers and all the best from Lake Constance :-)
Andreas
Senior Design/Application Engineer
E-Senza Technologies GmbH
Bücklestr. 82b
78467 Konstanz
Tel.: 07531 36599-10
www.e-senza.de
Amtsgericht Freiburg, HRB 382100. Geschäftsführer: Amit Shah
