EPICS on RTEMS 4.9 (for mvme2100 and mpc8313erdb)
Ralf Corsepius ralf.corsepius at rtems.org
Thu Oct 2 16:02:36 UTC 2008
On Thu, 2008-10-02 at 11:49 -0400, Phillip Sorensen wrote:
> > /opt/rtems-4.9/bin/powerpc-rtems4.9-gcc --pipe
> > -B/opt/rtems-4.9/powerpc-rtems4.9/mvme2100/lib/ -specs bsp_specs
> > -qrtems   -fasm -c   -mcpu=603e -Dmpc603e -Dppc603e
> > -DUNIX    -ansi  -O2 -g -mmultiple -mstring -mstrict-align -g
> > -Wall      -DMY_DO_BOOTP=NULL -DHAVE_PPCBUG
> > -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov <http://aps.anl.gov/>
Note this                                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
The quoting doesn't seem to be right - There are "'s missing.
> > -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
> > -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> > -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
> > -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
> > -I../../../src/libCom/env -I../../../src/libCom/error
> > -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
> > -I../../../src/libCom/gpHash -I../../../src/libCom/logClient
> > -I../../../src/libCom/macLib -I../../../src/libCom/misc
> > -I../../../src/libCom/osi -I../../../src/libCom/taskwd
> > -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
> > -I../../../include/os/RTEMS -I../../../include
> > ../../../src/libCom/bucketLib/bucketLib.c
> > powerpc-rtems4.9-gcc: error trying to exec 'cc1': execvp: No such file
> > or directory
> > as: unrecognized option `-mppc'
> I have been seeing basically the same error with the m68k tools trying
> to compile EPICS base 3.14.9.  If I add the directory with cc1 to the
> the path it seems to work.
Don't do this - Sorry, but this is wrong without any doubt.
>   I never had to do that with previous
> versions of RTEMS.
If what you say was true, we'd not be able to build RTEMS :)
> I was able yesterday to compile EPICS base 3.14.10-RC1 without a
> problem.  I have not looked for the difference yet.
Are you able to compile hello-world?
Also try adding "-v" to your CFLAGS and watch the output while compiling
hello-world.
Ralf
