Bootloader (Boot Loader)?
    Gene Smith
    gds at chartertn.net
    Fri Oct  3 18:06:05 UTC 2008
Ed Sutter wrote:
> Gene,
> I have booted RTEMS apps with MicroMonitor.  This is a bootloader
> that runs on most of the common CPUs, has its own NOR-based flash
> file system (onto which you would install your RTEMS image), and
> has networking, and a lot of other features you can configure in if
> needed.  If interested, take a look at
> http://www.microcross.com/html/micromonitor.html
> What CPU are you using?
Thanks, I will take a look at that. I am using ARM946.
> Ed Sutter
> Gene Smith wrote:
>> So far I have just been loading my RTEMS image to RAM via jtag and
>> running with a debugger. I would like to burn the image to Flash, along
>> with a boot loader of some sort, and have the loader copy the image to
>> RAM and beginning running. This would be a fairly rudimentary boot
>> loader just to get started.
>> Looking through the rtems archives I see some old references to Chris
>> John's "My Right Boot" and "Eric Norum's boot loader". Otherwise I can't
>> find these mentioned anywhere on RTEMS site (looked in ftp: contribs
>> etc.) or web.
>> I also see mention of Till's CEXP loader. If I understand it, it loads
>> random rtems applications. Not quite what I am looking for I don't think.
>> My board has no built-in boot loader, so I need to do something from
>> scratch. Ideally, the boot loader would need to do more such as possibly
>> help with f/w upgrade via network. I think this might require something
>> like u-boot or redboot. I think u-boot supports RTEMS but have not seen
>> it mentioned except on Erwin Rol's rtems/u-boot site and not updated
>> since maybe 2003. I have seen mention also of boards running RTEMS that
>> have built-in u-boot and how to deal with it, but not how to join u-boot
>> and RTEMS yourself.
>> Just wondering what others are doing for a boot loader.
>> Thanks,
>> -gene
