Can't read Card Specific Data from SD Card (rtems-4.9.0)
    Thomas Doerfler
    Thomas.Doerfler at embedded-brains.de
    Thu Oct  9 06:02:19 UTC 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Robert,
Sebastian is the specialist for the SDCard driver, but I have some
things to check for you:
Can you monitor the SPI signals at the SDCard with an oscilloscope, I
think the proper relationship between SEL, CLK and Data lines is crucial.
- - Did you verify the baudrate is correct (not too high)?
- - which is the real relationship between clock and the both data lines,
how much time is between the (de-)activation of SEL to the data transfers?
- - did you check with different SDcards?
maybe this will give some insights.
wkr,
Thomas.
Robert S. Grimes wrote:
> I've firmed up my hardware, and things seem much better. I seem to be
> able to reliably set SPI mode, initialize the card, and read the CID
> information. However, I cannot get the card to send its CSD. In order to
> attempt some progress, I've intentionally ignored errors when sending
> the SD_CARD_CMD_SEND_CSD command, and attempt to interpret the
> information that is returned, but it is all nonsense. This is the
> results from the aforementioned command:
> sd_card_send_command: Error: Response: ff:ff 49:ff 00:ff 00:ff 00:ff
> 00:ff 95:82
> ff:[7f] ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff
> I don't understand the 82 and 7f that it seems to find in the response
> data; shouldn't I see something like {ff} 01 {ff} fe <CSD bytes>?
> By the way, it seems I need to set both clock_inv and clock_phs true in
> the rtems_libi2c_tfr_mode_t structure used to set the transfer mode.
> This surprised me a bit, but then again, the other three combinations
> didn't work - I brute-forced it and tried all four, because I couldn't
> find documentation specifying which to use, and because nothing was
> working at the time ;-). Anyway, does that sound right?
> Any ideas? Thanks,
> -Bob
> P.S. Here is the full output as it stands:
>     sd_card_driver_init: Ok: Get driver entry
>     sd_card_start: Ok: Send start
>     virtex_spi_ioctl
>     virtex_spi_set_tfr_mode
>     virtex_spi_char_mode
>     sd_card_start: Ok: Set transfer mode
>     sd_card_start: Ok: Send address
>     sd_card_driver_init: Ok: Start
>     sd_card_driver_init: Ok: Register disk IO driver
>     sd_card_wait: Ok: Busy
>     sd_card_driver_init: Ok: Wait
>     sd_card_driver_init: Ok: Active chip select delay
>     sd_card_stop: Ok: Send stop
>     sd_card_driver_init: Ok: Stop
>     sd_card_driver_init: Ok: Send start
>     virtex_spi_ioctl
>     sd_card_driver_init: Ok: Set transfer mode
>     sd_card_driver_init: Ok: Inactive chip select delay
>     sd_card_driver_init: Ok: Send address
>     sd_card_stop_multiple_block_write: Ok: Wait
>     sd_card_stop_multiple_block_write: Ok: Write stop transfer token
>     sd_card_send_command: Ok: Wait
>     virtex_spi_ioctl
>     sd_card_send_command: Ok: Write command and read response
>     sd_card_send_command: Token [07]: 0xff
>     sd_card_send_command: Token [08]: 0xff
>     sd_card_send_command: Token [09]: 0xff
>     sd_card_send_command: Token [10]: 0xff
>     sd_card_send_command: Token [11]: 0xff
>     sd_card_send_command: Token [12]: 0xff
>     sd_card_send_command: Token [13]: 0xff
>     sd_card_send_command: Token [14]: 0xff
>     sd_card_send_command: Token [15]: 0xff
>     sd_card_send_command: Token [16]: 0xff
>     sd_card_send_command: Token [17]: 0xff
>     sd_card_send_command: Error: Timeout
>     sd_card_send_command: Error: Response: ff:ff 4d:ff 00:ff 00:ff 00:ff
>     00:ff 95:ff
>     ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:ff ff:[ff]
>     sd_card_stop_multiple_block_read: Ok: Write stop transfer token
>     virtex_spi_ioctl
>     sd_card_send_command: Token [08]: 0x01
>     sd_card_driver_init: Ok: Send: SD_CARD_CMD_GO_IDLE_STATE
>     virtex_spi_ioctl
>     sd_card_driver_init: Ok: Send: SD_CARD_CMD_APP_CMD
>     virtex_spi_ioctl
>     sd_card_driver_init: Ok: Send: SD_CARD_ACMD_SD_SEND_OP_COND
>     virtex_spi_ioctl
>     virtex_spi_ioctl
>     virtex_spi_ioctl
>     virtex_spi_ioctl
>     sd_card_send_command: Token [08]: 0x00
>     virtex_spi_ioctl
>     sd_card_send_command: Token [09]: 0x00
>     sd_card_driver_init: Ok: Send: SD_CARD_CMD_SEND_CID
>     sd_card_read: Search from 10 to 17
>     sd_card_read: Token [10]: 0xff
>     sd_card_read: Token [11]: 0xfe
>     sd_card_read: Ok: Read data
>     sd_card_read: Ok: Read CRC 16
>     sd_card_driver_init: Ok: Read: SD_CARD_CMD_SEND_CID
>     sd_card_driver_init: *** Card Identification ***
>     sd_card_driver_init: Manufacturer ID : 3
>     sd_card_driver_init: OEM/Application ID : 21316
>     sd_card_driver_init: Product name : SD01G€
>     sd_card_driver_init: Product revision : 0
>     sd_card_driver_init: Product serial number : 2696421888
>     sd_card_driver_init: Manufacturing date : 136
>     sd_card_driver_init: 7-bit CRC checksum : 27
>     virtex_spi_ioctl
>     sd_card_send_command: Token [07]: 0x7f
>     sd_card_send_command: Error: Command error [07]: 0x7f
>     00:ff 95:82
>     RSG: rv=-27
>     sd_card_driver_init: Ok: Send: SD_CARD_CMD_SEND_CSD
>     sd_card_read: Search from 8 to 17
>     sd_card_read: Token [08]: 0xff
>     sd_card_read: Token [09]: 0xff
>     sd_card_read: Token [11]: 0xff
>     sd_card_read: Token [12]: 0xff
>     sd_card_read: Token [13]: 0xff
>     sd_card_read: Token [14]: 0xff
>     sd_card_read: Token [15]: 0xff
>     sd_card_read: Token [16]: 0xff
>     sd_card_read: Error: Timeout
>     RSG: rv=-27
>     sd_card_driver_init: Ok: Read: SD_CARD_CMD_SEND_CSD
>     sd_card_driver_init: *** Card Specific Data ***
>     sd_card_driver_init: CSD structure : 0
>     sd_card_driver_init: Spec version : 0
>     sd_card_driver_init: Access time [ns] : 4500
>     sd_card_driver_init: Max access time [N] : 7053
>     sd_card_driver_init: Max read block size [B] : 1
>     sd_card_driver_init: Max write block size [B] : 1
>     sd_card_driver_init: Block size [B] : 1
>     sd_card_driver_init: Block number : 10488
>     sd_card_driver_init: Capacity [B] : 10488
>     sd_card_driver_init: Max transfer speed [b/s] : 450000000
>     virtex_spi_ioctl
> rtems-users mailing list
> rtems-users at rtems.com
Embedded Brains GmbH
Thomas Doerfler        Obere Lagerstrasse 30
D-82178 Puchheim       Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFI7Z5o7GwuYxrppv4RAknJAJ96MFZuI2Fi497xsgRTbBFXgAr2GgCcClyn
AyzYiY/xVk68NYw9owCgrW4=
=zSAr
-----END PGP SIGNATURE-----
