Can't read Card Specific Data from SD Card (rtems-4.9.0) - RESOLVED
Sebastian Huber
Fri Oct 10 07:24:18 UTC 2008
Robert S. Grimes wrote:
> Hi Thomas and Sebastian,
> Whew! This was a tough one!
> I finally figured it out. The culprit was sd_card_wait(), and its helper:
> static inline int sd_card_query( sd_card_driver_entry *e, uint8_t
> *in, int n)
> return rtems_libi2c_read_bytes( e->minor, in, n);
Oh, sorry for that. I should have mentioned the idle_char changes. In
the future the driver should support
read_write( src = NULL, dest = NULL, size = n)
To write n idle characters and discard the response.
In the current CVS head is also an experimental asynchronous read/write
interface for LibI2C (example driver is in libbsp/arm/lpc24xx/ssp/ssp.c).
> Now for the next stages - getting the file system working - wish me luck!
Good luck!
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
