Is there a flash-based FS in rtems?
Ed Sutter
esutter at alcatel-lucent.com
Thu Oct 23 16:31:22 UTC 2008
>>>> MicroMonitor has a simple NOR flash file system for managing updates
>>>> etc...
>>>> It hooks together with RTEMS pretty nicely. It's not designed for
>>>> heavy
>>>> file activity (no wear leveling), but does provide a nice platform
>>>> to support system updates etc...
>>>> Obviously, this would mean a bootloader change.
>>>> Ed
>>> Let me add a bit here, as I am using MicroMonitor as my bootloader,
>>> and I can vouch for its utility with application updates, etc. It
>>> also gives you scripting abilities for miscellaneous startup
>>> activities, such as running separate power-up tests before
>>> application startup, etc.
>>> If you need to access files on the MicroMonitor file system from your
>>> application (keeping Ed's caveat in mind, of course), you have two
>>> choices. The obvious approach is to call back into MicroMonitor, as
>>> documented in its User Manual; this would allow you the usual file
>>> operations (eg. read, write, etc.). I haven't used this approach, so
>>> I can't comment on it, but it seems certainly the way to go if you
>>> wish to create/write files.
>>> If you only need to read from files, for example, configuration
>>> files, etc., another (simpler?) option is not to use MicroMonitor at
>>> all from your application. This is made feasible because the file
>>> structure is extremely simple, with files being a single, contiguous
>>> region of memory _within the processor's address space_. Hence, you
>>> can simple set a pointer to the beginning of the file and treat it as
>>> a regular, in-memory data structure! (Note: these comments apply
>>> only to RAM and XOR Flash disks.) An exercise for the reader is
>>> determining the start location (and optionally, the size of the
>>> file) - of course, I can tell you how I did it if you are interested...
>> Actually, the uMon API makes it pretty easy to retrieve the starting
>> point
>> and size of the file in TFS. The call "mon_tfsstat(filename)" returns a
>> pointer to a structure that contains all that information. Then, as Bob
>> said, you can treat it just like a contiguous block of memory.
>> For writing, you can use the open/write/close model (similar, but not
>> identical to Unix), or you can just build an array in ram, then call
>> mon_tfsadd(name,flags,buffer,size) to create the file. Either way works,
>> it just depends on what you're comfortable with.
> Okay, Ed, here is another way to do it, without having to call into
> MicroMonitor (in case you are wondering, once my application is running,
> I'm not allowed to write to flash, which I accomplish by 1) not
> implementing any flash write/erase functionality, and 2) intentionally
> trashing MicroMonitor's RAM-resident image upon loading my app).
> Instead of using the API, use its most-excellent scripting ability to
> write a startup script that does something like this - here I want to
> make a file, named 'faults.dat', that resides in the flash TFS drive
> available to my application:
> # Create a RAM-base TFS "disk" - name is //var/
> tfs ramdev var 0x2d0000 0x130000
> # Expose fault file info
> tfs base faults.dat FAULTBASE
> tfs size faults.dat FAULTSIZE
> # Get the uMon environment and store it on //var
> set -f //var/environ
> # Find the enviroment file and make it known to ETILL
> tfs base //var/environ ENVBASE
> tfs size //var/environ ENVSIZE
> pm -4 $WELLKNOWNADDR $ENVBASE $ENVSIZE
> Now, the uMon environment (which consists of a string list of "set
> KEY=VALUE" pairs) is readily accessible by setting a pointer to
> $WELLKNOWNADDR, which then gives you access to the file's information.
> Note that this also give you access to any other environment variables
> you might have set in uMon; of course, the uMon API function
> mon_genenv() does this more easily, if you aren't restricted like I
> am... ;-)
Bob,
Cool! Neat idea
Thanks
