Problem with TCP socket on RTEMS 4.8.1 (ARM BSP)
Tue Sep 2 14:31:26 UTC 2008
Ralf Corsepius wrote:
> On Tue, 2008-09-02 at 08:32 -0500, Joel Sherrill wrote:
>> Gene Smith wrote:
>>> Alex Zolotov wrote, On 09/01/2008 01:41 AM:
>>>> Thank you.
>>>> It seems, that problem same as described by Gene Smith
>>>> (http://www.rtems.com/ml/rtems-users/2008/august/msg00073.html) in his
>>>> post "Little Endian ARM fails on 1st TCP datagram". The reason is that
>>>> BYTE_ORDER BIG_ENDIAN defined during compiling TCP functions.
>>> Yes, this BYTE_ORDER macro seems to be a current problem at least for
>>> ARM. Also mentioned in the previous thread.  -gene
>> Just to beat this one into submission.
> There is a bug in vanilla newlib, which has been supposed "fixed" in all
> current toolchain version - Otherwise we would not have been able to
> build rtems :)
> My most recent rtems-4.10-newlib patches contain another patch, which is
> trying to catch a corner case, we have been discarding so far.
>>   Are we are running the
>> ARM in big or little endian mode?
> Little endian.
>> If little endian, then the compiler has the correct predefine.
> Right.
>> /opt/rtems-4.10/bin/arm-rtems4.10-gcc
>> #define __ARMEL__ 1
>> /opt/rtems-4.6/bin/arm-rtems-gcc
>> #define __ARMEL__ 1
>> /opt/rtems-4.7/bin/arm-rtems4.7-gcc
>> #define __ARMEL__ 1
>> /opt/rtems-4.8/bin/arm-rtems4.8-gcc
>> #define __ARMEL__ 1
>> /opt/rtems-4.9/bin/arm-rtems4.9-gcc
>> #define __ARMEL__ 1
>> Where is the breakdown?
> Wish I knew that ;)
Me too.  Can someone give us a breaking case?  I don't
doubt something is broken but until it is reproduced
on this side, we can't do anything about it.
> Ralf
