copy of . data section
Fri Sep 5 07:07:57 UTC 2008
Hi,
you may have a look at the linker commands files (RTEMS CVS):
c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds
c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.memory
See also:
http://sourceware.org/binutils/docs-2.18/ld/Output-Section-LMA.html#Output-Section-LMA
Bassem Fahmy wrote:
> I'm currently doing a bsp for atmel sam7 i'm producing a .ELF. how can i copy the .data section from the flash to the data.
> this is the linker script i'm currently using.
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
