setitimer, getitimer() in rtems?
Gene Smith gds at chartertn.net
Fri Sep 5 14:37:07 UTC 2008
Joel Sherrill wrote:
> Gene Smith wrote:
>> Porting in some code that runs on linux, my last undefined link items
>> are setitimer and getitimer. I can't seem to find them in rtems (4.8.0)
>> except in the sys/time.h include file so it compiles. Saw some reference
>> to them in old mailing list threads that implied (or said?) that you
>> have to implement them using rtems native timer calls. Is this right?
> Since they use POSIX signals, you would implement them
> in the POSIX API (cpukit/posix) and implement them in terms
> of SuperCore timers.
> Why do you need these? And which of the three types
> (ITIMER_REAL, ITIMER_VIRTUAL, or ITIMER_PROF) do
> you want/need?
Why: The function is in some existing 3rd party code I need to use for
the project.
Which: Actually, the code only calls setitimer with parameter ITIMER_REAL.
Right now I am using rtems_timer_fire_after() with a callback function
to do a similar thing.
>> Thanks,
>> -gene
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
