Obtaining Semaphore in a Interrupt?
Thu Sep 11 18:21:06 UTC 2008
Manuel wrote:
> Hi.
> That is interesting. I had never thought of that before (an ISR could not
> release a semaphore with priority ceiling/inherance).
> By the way, is it possible to release a semaphore with priority
> ceiling/inherence inside the timer server task?
Yes but remember that when you use priority ceiling
or inheritance, there is the concept that it is a mutex
and that the same task that locked the mutex will unlock
it.  So if it was locked in the timer server task, then it
can be released there also.
FWIW the timer server task was added at the request of
a user who had specifically run into the case of a support
library using priority ceiling mutexes.  They has interrupt
based Timer Service Routines which were implicitly
calling these library mutexes.  Interesting breakage.
> I guess it should be possible since it is a task and has a priority, so the
> "new" priority will correspond to the original one when the release is
> performed (in practice, nothing will happen). But perhaps I'm missing some
> detail here...
No.  It is a normal task -- just one that you don't want to
block for long periods of time if you want the timers to
fire reasonably accurately. :)
> Kind Regards
> Manuel Coutinho
>> -----Original Message-----
>> From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
>> On Behalf Of Joel Sherrill
>> Sent: Wednesday, September 03, 2008 8:49 PM
>> To: Alexandre Constantino
>> Cc: rtems-users at rtems.com
>> Subject: Re: Obtaining Semaphore in a Interrupt?
>> Alexandre Constantino wrote:
>>> Hi
>>> Looking at the RTEMS user manual, inside an ISR it is not possible to
>> make blocking calls, such as rtems_semaphore_obtain.
>> I am glad the manual got that right. :-D
>>> Hence, to ensure mutual exclusion of an area accessed both by an
>> interrupt and a task you have to disable interrupts in that region.
>>> A semaphore cannot protect an area accessed by an ISR (because the ISR
>> cannot block).
>> Right.  Worse, see my comment below.
>>> Best regards,
>>> On Wednesday 03 September 2008, Leonard Bise wrote:
>>>> Hi all,
>>>> On the project I'm working on we need to protect a ressource from being
>>>> accessed by multiple tasks.
>>>> For this purpose we use a binary semaphore that is created in the
>>>> following manner :
>>>> sc = rtems_semaphore_create( rtems_build_name( 'D', 'R', 'V', 's' ), 1,
>>>>  RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY
>>>>                                               | RTEMS_PRIORITY,
>>>> RTEMS_NO_PRIORITY, &semDriver );
>> Creating a binary semaphore with the above characteristics
>> implies that it is being held by a thread.  You want to inherit
>> priority -- ISRs are not tasks and do not have priority.
>> Priority inheritance and ceiling come with the idea that the
>> mutex can be held by a thread which has priority and can be
>> changed.  It also implies that the holder will be the one releasing
>> the mutex so priorities can be restored correctly.
>> If you ever intend to even release a mutex/semaphore from
>> an ISR, it will have to be counting or simple binary which
>> do not include these semantics about priority and holder.
>>>> We use a board based on a LEON2 Processor and we use a few ISR as well.
>>>> These ISRs must often access the same protected ressources when
>> triggered.
>>>> The problem arise when we are in a task that is in the middle of
>> accessing
>>>> the protected ressources and that it obtains the semaphore and that
>>>> directly after an interrupt is triggered. The ISR would ask for a
>>>> semaphore when the last one was not released yet, because it is in the
>>>> middle of being processed. We then get a deadlock!
>>>> Could anyone please help me on this ? I guess the best way is to not
>> use
>>>> semaphore in ISR but how can i protect my ressource then !
>>>> The version used of RTEMS is 4.6.6
>>>> Regards,
>>>> Bise Léonard
>>> rtems-users mailing list
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
