Linking problem with libtelnetd
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Fri Sep 12 16:00:09 UTC 2008
Tim,
Tim Cussins schrieb:
> powerpc-rtems4.9-gcc -B../../../../../virtex/lib/ -specs bsp_specs -qrtems -
> mcpu=403 -Dppc405 -Dvirtex -O2 -g -fno-keep-inline-functions    -mcpu=403 -
> Dppc405 -Dvirtex    -o hello.exe init.o ../../../../../virtex/lib/no-
> barrier.rel ../../../../../virtex/lib/no-dpmem.rel
> ../../../../../virtex/lib/no-event.rel ../../../../../virtex/lib/no-msg.rel
> ../../../../../virtex/lib/no-mp.rel ../../../../../virtex/lib/no-part.rel
> ../../../../../virtex/lib/no-region.rel ../../../../../virtex/lib/no-
> signal.rel ../../../../../virtex/lib/no-timer.rel
> ../../../../../virtex/lib/no-rtmon.rel ../../../../../virtex/lib/no-ext.rel
I may be wrong, but I think you specify the path where ld should look
for libraries, but this does not mean that it will pull in any library
it finds there. AFAIK you really must add a "-ltelnetd" to tell ld to
look into ../../../../../virtex/lib/libtenetd.a.
wkr,
Thomas.
> init.o: In function `Init':
> /${MY_ABSOLUTE_PATH}/rtemscvs/rtems-4-9-branch/build/powerpc-
> rtems4.9/c/virtex/testsuites/samples/hello/../../../../../../../RTEMS-2008-09-11/c/src/../../testsuites/samples/hello/init.c:37:
> undefined reference to `rtems_telnetd_initialize'
> collect2: ld returned 1 exit status
> make: *** [hello.exe] Error 1
> ../../../../../virtex/lib/ contains all the usual (AFAIK) libs:
> -rw-r--r--  1      346 2008-09-12 11:21 bsp_specs
> -rwxr-xr-x  1   409199 2008-09-12 11:21 dirutils.rel
> drwxr-xr-x 20     4096 2008-09-12 11:21 include
> -rw-r--r--  1  1515488 2008-09-12 11:21 libcsupport.a
> -rw-r--r--  1    56608 2008-09-12 11:22 libftpd.a
> -rw-r--r--  1   465380 2008-09-12 11:22 libhttpd.a
> -rw-r--r--  1   235892 2008-09-12 11:21 libnfs.a
> -rw-r--r--  1  3424022 2008-09-12 11:21 libposix.a
> -rw-r--r--  1   462902 2008-09-12 11:22 libpppd.a
> -rw-r--r--  1   954366 2008-09-12 11:22 librtemsbsp.a
> -rw-r--r--  1 17303370 2008-09-12 11:22 librtemscpu.a
> -rw-r--r--  1   277206 2008-09-12 11:22 libshttpd.a
> -rw-r--r--  1   102202 2008-09-12 11:22 libtelnetd.a
> -rw-r--r--  1   218118 2008-09-12 11:22 libz.a
> -rw-r--r--  1     7230 2008-09-12 11:21 linkcmds
> -rwxr-xr-x  1   810555 2008-09-12 11:21 nfs.rel
> -rwxr-xr-x  1    16703 2008-09-12 11:22 no-barrier.rel
> -rwxr-xr-x  1     2116 2008-09-12 11:22 no-console.rel
> -rwxr-xr-x  1    16740 2008-09-12 11:22 no-dpmem.rel
> -rwxr-xr-x  1    16531 2008-09-12 11:22 no-event.rel
> -rwxr-xr-x  1    16701 2008-09-12 11:22 no-ext.rel
> -rwxr-xr-x  1    20763 2008-09-12 11:22 no-filesystem.rel
> -rwxr-xr-x  1    18664 2008-09-12 11:22 no-io.rel
> -rwxr-xr-x  1     1762 2008-09-12 11:22 no-mp.rel
> -rwxr-xr-x  1    16725 2008-09-12 11:22 no-msg.rel
> -rwxr-xr-x  1    16702 2008-09-12 11:22 no-part.rel
> -rwxr-xr-x  1    16697 2008-09-12 11:22 no-region.rel
> -rwxr-xr-x  1    16728 2008-09-12 11:22 no-rtmon.rel
> -rwxr-xr-x  1    16761 2008-09-12 11:22 no-sem.rel
> -rwxr-xr-x  1    16537 2008-09-12 11:22 no-signal.rel
> -rwxr-xr-x  1    16687 2008-09-12 11:22 no-timer.rel
> -rwxr-xr-x  1   441117 2008-09-12 11:21 rpcio.rel
> -rw-r--r--  1     1524 2008-09-12 11:22 rtems_crti.o
> Ideas?
> Tim
> rtems-users mailing list
> rtems-users at rtems.com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
