ARM Initialization Question
Mon Sep 15 12:02:07 UTC 2008
Joel Sherrill wrote:
> Sebastian Huber wrote:
>> Hi,
>> I am quite new to the ARM architecture and try to develop a BSP for the
>> LPC2478.  I have a question to the initialization code (random start.S):
> Just firing a warning shot .. I am starting to refactor out
> more common code from the BSPs.  Please try to help out
> by moving with me to the better place. :)
> + You know about bsp_get_work_area.  I am starting to
>     put it in "startup/bspgetworkarea.c" not bspstart.c
>     and reworking all BSPs to have one.
I try to provide two general purpose linker command files (one for RAM
only and one for code in ROM).  With such a linker command file it is
possible to use a generic version of bsp_get_work_area().  Reducing the
amount of linker command files increases the maintainablity and makes
development of new BSPs easier.  Here is my proposal for the ARM:
  * @file
  * @brief Linker command file for configuration with internal and
external RAM.
  * Copyright (c) 2008
  * Embedded Brains GmbH
  * Obere Lagerstr. 30
  * D-82178 Puchheim
  * Germany
  * rtems at embedded-brains.de
  * The license and distribution terms for this file may be found in the
file
  * LICENSE in this distribution or at http://www.rtems.com/license/LICENSE.
OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
OUTPUT_ARCH (arm)
ENTRY (start)
  * BSP: Symbols that may be defined externally.  The minimum alignment
  * requirement for regions is bsp_section_align.
bsp_ram_int_size = DEFINED (bsp_ram_int_size) ? bsp_ram_int_size :
LENGTH (RAM_INT);
bsp_ram_ext_size = DEFINED (bsp_ram_ext_size) ? bsp_ram_ext_size :
LENGTH (RAM_EXT);
bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size :
128;
bsp_stack_fiq_size = DEFINED (bsp_stack_fiq_size) ? bsp_stack_fiq_size :
128;
bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size :
256;
bsp_stack_svc_size = DEFINED (bsp_stack_svc_size) ? bsp_stack_svc_size :
256;
bsp_stack_undef_size = DEFINED (bsp_stack_undef_size) ?
bsp_stack_undef_size : 128;
  * BSP: Global symbols
bsp_ram_int_start = ORIGIN (RAM_INT);
bsp_ram_int_end = bsp_ram_int_start + bsp_ram_int_size;
bsp_ram_ext_start = ORIGIN (RAM_EXT);
bsp_ram_ext_end = bsp_ram_ext_start + bsp_ram_ext_size;
bsp_section_align = 16;
bsp_stack_align = 16;
SECTIONS {
   .vector : {
      * BSP: Start of vector section
     bsp_section_vector_start = .;
      * BSP: Reserve space for the exception vector table and
      * the pointers to the default exceptions handlers.
     . = . + 64;
     . = ALIGN (bsp_section_align);
      * BSP: End of vector section
     bsp_section_vector_end = .;
   } > RAM_INT
   .text : {
      * BSP: Start of text section
     bsp_section_text_start = .;
      * BSP: System startup entry
     KEEP (*(.entry))
      * BSP: Moved into .text from .init
     KEEP (*(.init))
     *(.text .stub .text.* .gnu.linkonce.t.*)
     KEEP (*(.text.*personality*))
     /* .gnu.warning sections are handled specially by elf32.em.  */
     *(.gnu.warning)
      * BSP: Magic ARM stuff
     *(.ARM.*)
     *(.glue_7)
     *(.glue_7t)
     *(.vfp11_veneer)
      * BSP: Special FreeBSD sysctl sections
     . = ALIGN (16);
     __start_set_sysctl_set = .;
     *(set_sysctl_*);
     __stop_set_sysctl_set = ABSOLUTE(.);
     *(set_domain_*);
     *(set_pseudo_*);
      * BSP: Moved into .text from .*
     *(.rodata .rodata.* .gnu.linkonce.r.*)
     *(.rodata1)
     *(.eh_frame_hdr)
      * BSP: Required by cpukit/score/src/threadhandler.c
     PROVIDE (_fini = .);
      * BSP: Moved into .text from .fini
     KEEP (*(.fini))
      * BSP: End of text section
     bsp_section_text_end = .;
   } > RAM_EXT
   .data : {
      * BSP: Start of data section
     bsp_section_data_start = .;
      * BSP: Moved into .data from .ctors
     /* gcc uses crtbegin.o to find the start of
        the constructors, so we make sure it is
        first.  Because this is a wildcard, it
        doesn't matter if the user does not
        actually link against crtbegin.o; the
        linker won't look for a file to match a
        wildcard.  The wildcard also means that it
        doesn't matter which directory crtbegin.o
        is in.  */
     KEEP (*crtbegin.o(.ctors))
     KEEP (*crtbegin?.o(.ctors))
     /* We don't want to include the .ctor section from
        the crtend.o file until after the sorted ctors.
        The .ctor section from the crtend file contains the
        end of ctors marker and it must be last */
     KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
     KEEP (*(SORT(.ctors.*)))
     KEEP (*(.ctors))
      * BSP: Moved into .data from .dtors
     KEEP (*crtbegin.o(.dtors))
     KEEP (*crtbegin?.o(.dtors))
     KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
     KEEP (*(SORT(.dtors.*)))
     KEEP (*(.dtors))
      * BSP: Moved into .data from .*
     *(.data1)
     KEEP (*(.eh_frame))
     *(.gcc_except_table .gcc_except_table.*)
     KEEP (*(.jcr))
     *(.data .data.* .gnu.linkonce.d.*)
     KEEP (*(.gnu.linkonce.d.*personality*))
     SORT(CONSTRUCTORS)
      * BSP: End of data section
     bsp_section_data_end = .;
   } > RAM_EXT
   .bss : {
      * BSP: Start of bss section
     bsp_section_bss_start = .;
     *(COMMON)
     *(.dynbss)
     *(.bss .bss.* .gnu.linkonce.b.*)
      * BSP: End of bss section
     bsp_section_bss_end = .;
   } > RAM_EXT
   .stack : {
      * BSP: Start of stack section
     bsp_section_stack_start = .;
     . = ALIGN (bsp_stack_align);
     bsp_stack_abt_start = .;
     . = . + bsp_stack_abt_size;
     bsp_stack_fiq_start = .;
     . = . + bsp_stack_fiq_size;
     bsp_stack_irq_start = .;
     . = . + bsp_stack_irq_size;
     bsp_stack_svc_start = .;
     . = . + bsp_stack_svc_size;
     bsp_stack_undef_start = .;
     . = . + bsp_stack_undef_size;
      * BSP: End of stack section
     bsp_section_stack_end = .;
   } > RAM_INT
   .work_area : {
      * BSP: Start of work area.  The work area will occupy the remaining
      * RAM_EXT region and contains the RTEMS work space and heap.  We
cannot
      * assign the region end directly since this leads to a region full
      * warning.
     bsp_work_area_start = .;
     . = bsp_ram_ext_end - 4;
      * BSP: End of work area
     bsp_work_area_end = .;
   } > RAM_EXT
   bsp_section_vector_size = bsp_section_vector_end -
bsp_section_vector_start;
   bsp_section_text_size = bsp_section_text_end - bsp_section_text_start;
   bsp_section_data_size = bsp_section_data_end - bsp_section_data_start;
   bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_start;
   bsp_section_stack_size = bsp_section_stack_end - bsp_section_stack_start;
   bsp_work_area_size = bsp_work_area_end - bsp_work_area_start;
   /* Stabs debugging sections.  */
   .stab          0 : { *(.stab) }
   .stabstr       0 : { *(.stabstr) }
   .stab.excl     0 : { *(.stab.excl) }
   .stab.exclstr  0 : { *(.stab.exclstr) }
   .stab.index    0 : { *(.stab.index) }
   .stab.indexstr 0 : { *(.stab.indexstr) }
   .comment       0 : { *(.comment) }
   /* DWARF debug sections.
      Symbols in the DWARF debugging sections are relative to the beginning
      of the section so we begin them at 0.  */
   /* DWARF 1 */
   .debug          0 : { *(.debug) }
   .line           0 : { *(.line) }
   /* GNU DWARF 1 extensions */
   .debug_srcinfo  0 : { *(.debug_srcinfo) }
   .debug_sfnames  0 : { *(.debug_sfnames) }
   /* DWARF 1.1 and DWARF 2 */
   .debug_aranges  0 : { *(.debug_aranges) }
   .debug_pubnames 0 : { *(.debug_pubnames) }
   /* DWARF 2 */
   .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
   .debug_abbrev   0 : { *(.debug_abbrev) }
   .debug_line     0 : { *(.debug_line) }
   .debug_frame    0 : { *(.debug_frame) }
   .debug_str      0 : { *(.debug_str) }
   .debug_loc      0 : { *(.debug_loc) }
   .debug_macinfo  0 : { *(.debug_macinfo) }
   /* SGI/MIPS DWARF 2 extensions */
   .debug_weaknames 0 : { *(.debug_weaknames) }
   .debug_funcnames 0 : { *(.debug_funcnames) }
   .debug_typenames 0 : { *(.debug_typenames) }
   .debug_varnames  0 : { *(.debug_varnames) }
   /* DWARF 3 */
   .debug_pubtypes 0 : { *(.debug_pubtypes) }
   .debug_ranges   0 : { *(.debug_ranges) }
   .gnu.attributes 0 : { KEEP (*(.gnu.attributes)) }
   /DISCARD/ : {
     *(.note.GNU-stack) *(.gnu_debuglink)
    * BSP: Catch all unknown sections
   .nirvana : {
   } > NIRVANA
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
