Linking problem with libtelnetd
Gene Smith gds at chartertn.net
Mon Sep 15 13:37:01 UTC 2008
Thomas Doerfler (nt) wrote:
> I may be wrong, but I think you specify the path where ld should look
> for libraries, but this does not mean that it will pull in any library
> it finds there. AFAIK you really must add a "-ltelnetd" to tell ld to
> look into ../../../../../virtex/lib/libtenetd.a.
> wkr,
> Thomas.
Also, -ltelnetd needs to last (or after things that use it) on the final
link command line.
