4.9 Testing Request
Robert S. Grimes rsg at alum.mit.edu
Thu Sep 18 12:00:21 UTC 2008
Ralf Corsepius wrote:
> On Wed, 2008-09-17 at 21:11 -0400, Robert S. Grimes wrote:
>> I'm having trouble installing the 4.9-testing code with 4.10 tools.  It
>> builds just fine, but fails during the installation.
>> Here is the end of the build output:
>>  /usr/bin/install -c -m 644
>> '../../../../../../rtems-cvs-20080911/c/src/../../cpukit/posix/inline/rtems/posix/barrier.inl'
>> '/usr/rtems/4.9/powerpc-rtems/virtex/lib/include/rtems/posix/barrier.inl'
>> '../../../../../../rtems-cvs-20080911/c/src/../../cpukit/posix/inline/rtems/posix/rwlock.inl'
>> '/usr/rtems/4.9/powerpc-rtems/virtex/lib/include/rtems/posix/rwlock.inl'
>> '../../../../../../rtems-cvs-20080911/c/src/../../cpukit/posix/inline/rtems/posix/spinlock.inl'
>> '/usr/rtems/4.9/powerpc-rtems/virtex/lib/include/rtems/posix/spinlock.inl'
>> test -z "/usr/rtems/4.9/powerpc-rtems/virtex/lib" || /bin/mkdir -p
>>  /usr/bin/install -c -m 644 'libposix.a'
>> '/usr/rtems/4.9/powerpc-rtems/virtex/lib/libposix.a'
>>  powerpc-rtems-ranlib '/usr/rtems/4.9/powerpc-rtems/virtex/lib/libposix.a'
>> /bin/bash: line 4: powerpc-rtems-ranlib: command not found
>> Seems it can't find powerpc-rtems-ranlib, yet it does exist, and in the
>> same directory as the other tools, so the path is correct.  Any ideas?
> Which --target did you pass to configure?
> powerpc-rtems-ranlib indicates you to have used --target=powerpc-rtems
Yes, you are correct.
> This should be --target=powerpc-rtems4.9 (to use the powerpc-rtems4.9
> toolchain) rsp. --target=powerpc-rtems4.10 (to use the powerpc-rtems4.10
> toolchain).
Is this true in an absolute sense, or by convention?  Let me explain
what I mean.
First, I've never used more than one set of tools, one target, or even
one RTEMS version at a time, and what I've used has worked fine.  Now, I
am attempting to use two different environments (my existing 4.8.0-based
and the 4.9-testing configurations), so maybe my approach is not "best
practice".  Anyway, my 4.8.0 environment was set up using
--prefix=/usr/rtems/4.8 for the install point, and
--target=powerpc-rtems when configuring the tools and BSP.  So, for
example, the compiler was named "powerpc-rtems-gcc", and it lives in
"/usr/rtems/4.8/bin".  My PATH environment variable is set to
"/usr/rtems/4.8/bin:...", and RTEMS_MAKEFILE_PATH is set to
"/usr/rtems/4.8/powerpc-rtems/virtex".
This works fine, so I was trying to set up the tools and 4.9-testing
using the same approach:
  target =>  <cpufamily>-rtems
  installpoint => /usr/rtems/<version>
  tools => /usr/rtems/<version>/<target>
So different versions of tools (and I guess, different targets too) are
stored in separate locations, and the choice as to which to use is based
on the PATH environment setting.  This is the same approach suggested
for the selection of BSP via the RTEMS_MAKEFILE_PATH variable.
You seem to suggest I should name the tools with the version number,
which I don't have a strong opinion about.  You guys do a lot more of
this multi-version, multi-target stuff than I do, so I'm happy to use
"best practices" - once I understand them, of course!  :-)
But is that the cause of my problem?  Wouldn't things have broken long
before, when powerpc-rtems4.10-gcc was not found?
I must be mistaken in my understanding here...
> Background: Somewhat oversimplified, the TARGET specified in
> --target=TARGET is the toolchain prefix of the toolchain to be used.
Yes, I understood that.
> Ralf
Thanks,
-Bob
