603e Clock Issue -- Decrementer Problem
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Sep 19 16:46:14 UTC 2008
Hi,
Jennifer has been fighting this for a few days and
we don't see it. She is testing the score603e BSP
on the head and it appears that something strange
is going on with the decrementer. We have no more
ideas and would appreciate some new insights. The
following is Jennifer's description.
I'm debugging the score603e bsp off the head of the tree and can't seem to
get the decrementer to set. I modified clockOn as indicated below. I
have tried
several modifications to the PPC_Get_decrementer and PPC_Set_decrementer
routines,
looked at the assembly and I can't see whats wrong. Any help would be
appreciated.
void clockOn(void* unused)
rtems_interrupt_level l;
volatile uint32_t decValue;
uint32_t msr_value;
_CPU_MSR_GET( msr_value );
printk("MSR: 0x%x\n", msr_value );
PPC_Get_decrementer( decValue );
printk("clockOn: Decrementer at 0x%x\n", decValue );
PPC_Set_decrementer( Clock_Decrementer_value );
Processor_Synchronize();
printk("clockOn: Setting decrementer to 0x%x\n",
if ( ppc_cpu_is_bookE() ) {
printk("ppc_cpu_is_bookE\n");
My Output looks like the following:
bsp_start (Top): Decrementer at 0xFFD4DAA1
bsp_start: Zero out lots of memory
Cpu: 0x7 Revision: 4609
Cpu MPC603ev
<snip>
MSR: 0x2030
clockOn: Decrementer at 0xFFE5C5B7
clockOn: Setting decrementer to 0xA1220
clockOn: Decrementer at 0xFFFEF1AA
<<=== JOEL HERE: notice that the value read indicates that the set never
occurred. We have both looked at the assembly and don't see how this
could happen. There is a mtdec between the two prints.
Below is the compilation options on the file:
powerpc-rtems4.9-gcc --pipe -B../../../../.././lib/
-B../../../../.././score603e/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_VERSION=\"4.8.99.0\"
-DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.8.99.0\"
-DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -I.
-I../../../../../../../rtems-work/rtems/c/src/lib/libcpu/powerpc
-isystem ../../../../.././score603e/lib/include -Wall
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
-mcpu=603e -Dppc603e -O2 -g -fno-keep-inline-functions -MT
mpc6xx/clock/mpc6xx_clock_rel-c_clock.o -MD -MP -MF
mpc6xx/clock/.deps/mpc6xx_clock_rel-c_clock.Tpo -c -o
mpc6xx/clock/mpc6xx_clock_rel-c_clock.o `test -f
'mpc6xx/clock/c_clock.c' || echo
'../../../../../../../rtems-work/rtems/c/src/lib/libcpu/powerpc/'`mpc6xx/clock/c_clock.c
Thanks. (from joel and jennifer)
