Proposed addition to libi2c transfer mode structure for SPI chip select generation
Robert S. Grimes
rsg at alum.mit.edu
Fri Sep 19 16:40:50 UTC 2008
Hi all,
The Xilinx Virtex-4 and Virtex II-Pro SPI peripherals support
automatically generating per-byte chip selects (CS) for communicating
over the SPI bus. This mode is in addition to a manual mode, in which
software must manually set CS. The automatic mode is very cool for
those devices that use CS to frame each byte (or in a custom version of
the SPI peripheral I have, each 16-bit word). However, other devices,
such as Ramtron FRAM, expect the CS to be used as a "transaction" frame,
which is where the manual mode comes in.
When I implemented my SPI driver, I needed to support both modes (as I
have examples of each device type), but I couldn't find where to capture
this option. It seems to logically fit into the rtems_libi2c_tfr_mode_t
structure, as it is related to those attributes, so that is what I did
in my 4.8 installation. I would like to see this incorporated into
RTEMS (hopefully 4.9), so the Virtex SPI driver will work. Here is the
single change, in /cpukit/libi2c/libi2c.h:
typedef struct {
uint32_t baudrate; /* maximum bits per second */
/* only valid for SPI drivers: */
uint8_t bits_per_char; /* how many bits per byte/word/longword? */
bool lsb_first; /* true: send LSB first */
bool clock_inv; /* true: inverted clock (high active) */
bool clock_phs; /* true: clock starts toggling at start of
data tfr */
uint32_t idle_char; /* This character will be continuously
transmitted in read only functions */
+ bool spi_sel_mode; /* SPI only - true = SS set per
transaction; false = SS set per SPI word */
} rtems_libi2c_tfr_mode_t;
Any comments?
I also can submit my SPI driver, though it is currently polled mode
only; that was sufficient for my needs, and I couldn't get the
interrupts to work correctly. Perhaps by submitting it someone else
could help? Regardless, it does work fine as is, with that caveat.
Thanks,
-Bob
