General PTY and CONSOLE question--SOLVED
Mon Sep 22 13:50:06 UTC 2008
Gene Smith wrote:
> Gene Smith wrote, On 09/21/2008 08:23 PM:
>> failed internally with no CONSOLE driver enabled. You end up with a
>> stack like this:
>> Kbhit()  <--- my function
>> rtems_panic
>> rtems_verror
>> _exit
>> newlibc_exit
>> close(stdin/stdout/stderr)
>> soisdisconnected   <--sets SS_CANTRCVMORE bit that accept() fails on.
> The stack actually looks like this (eventually you reach
> soisdisconnected() as shown above):
> (arm-gdb) bt
> #0  rtems_bsdnet_close (iop=0x202ca83c) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libnetworking/rtems/rtems_syscall.c:672
> #1  0x201b2f9c in close (fd=0) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/close.c:33
> #2  0x201b302c in _close_r (ptr=0x2022d70c, fd=0) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/close.c:56
> #3  0x2021b2cc in _fclose_r (rptr=0x2022d70c, fp=0x2022da54) at
> ../../../../../gcc-4.2.4/newlib/libc/stdio/fclose.c:93
> #4  0x201b6370 in libc_wrapup () at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:88
> #5  0x201b63f4 in _exit (status=0) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:131
> #6  0x201b32e4 in rtems_verror (error_flag=536870912,
> printf_format=0x202325d8 "bad tcgetattr", arglist=0x202523b0) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/error.c:162
> #7  0x201b33d0 in rtems_panic (printf_format=0x20164304 "") at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/error.c:210
> #8  0x2016af00 in kbhit () at
> /home/gene/4.8.0-rtems/tools/network-demos-4.8.0/adapter/ertek209/cep/src/linux_conio.c:102
> #9  0x201663ac in eip_cycle () at
> /home/gene/4.8.0-rtems/tools/network-demos-4.8.0/adapter/ertek209/cep/src/EepSample.c:515
> #10 0x201583cc in Init (ignored=0) at
> /home/gene/4.8.0-rtems/tools/network-demos-4.8.0/adapter/ertek209/mgt/src/init.c:99
> #11 0x2021aeb4 in _Thread_Handler () at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/score/src/threadhandler.c:137
> #12 0x2021adf0 in _Thread_Is_heir (the_thread=0x202522b0) at
> ../../cpukit/../../../csb337/lib/include/rtems/score/thread.inl:60
I think newlib/exit is doing what we expect it to do -- close stdin, out
and error.  The system is not in an unusual state (critical section or
shutting down).
Is it possible that these sequences are not in the same thread? Or are
we closing a socket that is not completely/correctly initialized?
I can't connect the pieces in my head to see what went wrong.  Is
the socket closed twice?  Not completely initialized?
Can you put some traces into soclose() at uipc_socket.c:156 so
we can tell if this is the first or second close?
The malloc message is often indicative of a double free.
During symbol reading, incomplete CFI data; unspecified registers (e.g.,
> r0) at 0x201b5e7c.
> 0x0) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libcsupport/src/malloc.c:495
> 495         printk( "Program heap: free of bad pointer %p -- range %p -
> %p \n",
> Current language:  auto; currently c
> (arm-gdb) bt
> #0  free (ptr=0x2031d150) at
> #1  0x201cd798 in rtems_bsdnet_free (addr=0x2031d150, type=3) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libnetworking/rtems/rtems_glue.c:137
> #2  0x201e5cac in sofree (so=0x201ce8b8) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/libnetworking/kern/uipc_socket.c:156
> #3  0x02000000 in ?? ()
> Backtrace stopped: previous frame inner to this frame (corrupt stack?)
> (arm-gdb)
> rtems-users mailing list
> rtems-users at rtems.com
