RES: Make install problem with v4.8.0 on fedora9
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Mon Sep 22 14:54:45 UTC 2008
Hello, Arquer,
Are the RTEMS tools in your path (PATH environment variable)?
Or, Are ALL RETMS tools installed?
Note that "sparc-rtems4.8-ranlib" was not found.
Att.
Wendell P. Silva
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Arquer Stephane
Enviada em: segunda-feira, 22 de setembro de 2008 11:49
Para: rtems-users at rtems.com
Assunto: Make install problem with v4.8.0 on fedora9
Hello,
I'm trying to compile rtems 4.8.0 on a fedora 9, configure and make command succeeded but the make install break with the following error msg:
Making install in libmd
gmake[4]: entrant dans le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/libmd »
gmake[5]: entrant dans le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/libmd »
gmake[5]: Rien à faire pour « install-exec-am ».
gmake[5]: Rien à faire pour « install-data-am ».
gmake[5]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/libmd »
gmake[4]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/libmd »
Making install in wrapup
gmake[4]: entrant dans le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/wrapup »
gmake[5]: entrant dans le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/wrapup »
test -z "/opt/rtems-4.8/sparc-rtems4.8/leon3/lib" || /bin/mkdir -p "/opt/rtems-4.8/sparc-rtems4.8/leon3/lib"
/usr/bin/install -c -m 644 'librtemscpu.a' '/opt/rtems-4.8/sparc-rtems4.8/leon3/lib/librtemscpu.a'
sparc-rtems4.8-ranlib '/opt/rtems-4.8/sparc-rtems4.8/leon3/lib/librtemscpu.a'
/bin/sh: line 4: sparc-rtems4.8-ranlib: command not found
gmake[5]: *** [install-project_libLIBRARIES] Erreur 127
gmake[5]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/wrapup »
gmake[4]: *** [install-am] Erreur 2
gmake[4]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit/wrapup »
gmake[3]: *** [install-recursive] Erreur 1
gmake[3]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3/cpukit »
gmake[2]: *** [install-recursive] Erreur 1
gmake[2]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c/leon3 »
gmake[1]: *** [install-recursive] Erreur 1
gmake[1]: quittant le répertoire « /home/arquers/rtems/rtems-4.8.0/build/sparc-rtems4.8/c »
make: *** [install-recursive] Erreur 1
[arquers at localhost build]$
Does anybody know this problem ?
Thanks for help.
Stephane.
rtems-users mailing list
http://rtems.rtems.org/mailman/listinfo/rtems-users
