General PTY and CONSOLE question--SOLVED
Gene Smith gds at chartertn.net
Tue Sep 23 14:29:54 UTC 2008
Joel Sherrill wrote, On 09/23/2008 09:39 AM:
> Chris Johns wrote:
>> Joel Sherrill wrote:
>>> Sounds like the socket close code has no idea that it shouldn't
>>> close it a second time.  Somehow we get deep in the bowels
>>> for a closed file descriptor.  I wonder if simply calling close()
>>> twice on a socket fd would reproduce the problem.
>> I think this is bug 785.
>> (https://www.rtems.org/bugzilla/show_bug.cgi?id=785)
> Gene.. can you confirm this fixes your situation?  If so,
> I would like to apply this patch to all open branches and
> the head.
Joel,Chris,
This may indeed be a bug but I don't think it is what I am seeing
exactly. First, this assumes you have already blocked in accept(). In my
situation I have not yet blocked in accept. I go into accept() and then
return when I see that the SS_CANTRECEIVEMORE flag is set. This flag is
set when the code chain beginning with fclose(stdin) occurs
(improperly?) with no console driver installed after calling
rtems_panic() in another thread.
Also, the patches are against 4.6 and 4.7. Not sure if they are OK with
4.8.0 which I have. Can you send me an updated patch or, even better,
the complete files with the patch applied and I will try them? You can
send to gd.smth at gmail dot com.  (Yes, smth is right).
-gene
