Etherboot on Elan SC520
Tue Sep 23 20:31:03 UTC 2008
Hi,
I am trying to resurrect an old PC-104 system
we have here at OAR (Versalogic Bobcat) and
have an Etherboot image which appears to load
the RTEMS executable and then do nothing else.
I have Etherboot configured to do IO on both
the VGA and COM1 so was able to cut and paste
this:
Probing pci nic...
[82559er]Ethernet addr: 00:04:BF:80:0A:98
Using Static IP Information...
Me: 192.168.1.248, TFTP: 192.168.1.3, Gateway 192.168.1.14
Loading 192.168.1.3:/bobcat.img XXXX(0119K done
Etherboot 5.4.3 [build JOEL6 #1] (GPL) http://etherboot.org
Drivers: EEPRO100   Images: NBI ELF Multiboot PXE   Exports: PXE
Protocols: DHCP TFTP
Relocating _text from: [00010420,0001c9f0) to [03ef3a30,03f00000)
Boot from (N)etwork or (Q)uit? N
Probing pci nic...
Loading 192.168.1.3:/bobcat.img XXXX(ELF)... Multiboot0111K done
I added a printk at the top of bsp_start and don't
see it.
I don't know if the addresses in the Relocating
line above are OK or what is expected output.
Any hints from you Etherboot'ers on the list would
be appreciated.
