Build Problem under Cygwin
Ralf Corsepius ralf.corsepius at rtems.org
Fri Sep 26 17:57:08 UTC 2008
On Fri, 2008-09-26 at 11:22 -0400, Robert S. Grimes wrote:
> Okay, a hunch occurred to me after mailing this, so I'd like to ask a
> different. question: how could I have gotten DOS end of lines into the
> autoconf source?
> The RTEMS source tree is different, however. I again used tar, but this
> time on a Linux machine, to unpack 4.9.0 and put it under revision
> control (vendor branch under Subversion). Later, I checked it into my
> Cygwin host and am attempting to build that. I'll have to figure out
> where the DOS EOLs came from there...
> So my questions now are these:
> 1. Any idea how I could have gotten DOS EOL chars into the autoconf
> source tree?
Are you using a "text" mounted cygwin partition?
Try using a binary mounted partitions.
Ralf
