ELF file to .bin convertion (mpc8313erdb)
Yuke Tian ytian at bnl.gov
Fri Sep 26 19:20:12 UTC 2008
Hi,
I built an RTEMS application on mpc8313erdb (start supported from 4.9).
The board come with a pre-installed U-boot to allow download application
into memory and run. But it seems U-boot only support .bin raw binary
image.  The .exe or .o files generated from the Makefile are all ELF
32-bit MSB executable files.  Does anyone know what tools I should use
to convert the ELF to .bin format for this powerpc CPU ?  Specifically
for this board, which memory address I should load the .bin file.
Thanks,
Yuke
