ELF file to .bin convertion (mpc8313erdb)
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Sat Sep 27 09:53:08 UTC 2008
Hi,
you don't need a raw binary file, but U-Boot requires a properly
formatted image file (in a specific U-Boot format).
First you need the U-Boot formatter "mkimage", which you can build from
the U-Boot sources.
Then the following steps are needed (here to format the "ticker.exe"):
powerpc-rtems4.10-objcopy -R -S -O binary ticker.exe ticker.bin
cat ticker.bin | gzip >ticker.gz
tools/mkimage -Appc -O rtems -T kernel -a 0x100 -e 0x10000 -n "RTEMS"\
 -d ticker.gz ticker.img
The resulting "ticker.img" can be loaded via TFTP or other means e.g.
with the following U-Boot commands:
setenv ipaddr 192.168.96.92
setenv serverip 192.168.96.1
tftpboot 0x400000 mpc8313erdb_ticker.img
bootm 0x400000
wkr,
Thomas.
Yuke Tian schrieb:
> Hi,
> I built an RTEMS application on mpc8313erdb (start supported from 4.9).
> The board come with a pre-installed U-boot to allow download application
> into memory and run. But it seems U-boot only support .bin raw binary
> image.  The .exe or .o files generated from the Makefile are all ELF
> 32-bit MSB executable files.  Does anyone know what tools I should use
> to convert the ELF to .bin format for this powerpc CPU ?  Specifically
> for this board, which memory address I should load the .bin file.
> Thanks,
> Yuke
> rtems-users mailing list
> rtems-users at rtems.com
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
