build rtems-4.8 error
朱旭峰 fall4ufeng at gmail.com
Sun Sep 28 03:59:08 UTC 2008
hi all:
      I met following errors when I built rtems-4.8.The commands I used
were:
       command:  ../rtems-4.6.6-1.0.0/configure --target=sparc-rtems
                          gmake RTEMS_BSP="arc810"
       errors:
sparc-rtems-gcc --pipe -DHAVE_CONFIG_H   -I../../..
-I../../../../cpukit/../../../leon3/lib/include  -Wall -fasm -mcpu=cypress
-msoft-float -O2 -g -MT libscorecpu_a-cpu.o -MD -MP -MF
.deps/libscorecpu_a-cpu.Tpo -c -o libscorecpu_a-cpu.o `test -f 'cpu.c' ||
echo
'../../../../../../../../rtems-4.8/c/src/../../cpukit/score/cpu/sparc/'`cpu.c
In file included from
../../../../../../leon3/lib/include/rtems/score/cpu.h:28,
                 from
../../../../../../leon3/lib/include/rtems/system.h:162,
                 from
../../../../../../../../rtems-4.8/cpukit/score/cpu/sparc/cpu.c:14:
../../../../../../leon3/lib/include/rtems/score/types.h:34: syntax error
before "Priority_Bit_map_control"
../../../../../../leon3/lib/include/rtems/score/types.h:34: warning: type
defaults to`int' in declaration of `Priority_Bit_map_control'
      so,anyone can give some tips?
URL: <http://lists.rtems.org/pipermail/users/attachments/20080928/ef1ab26f/attachment.html>
