POSIX FIFO/pipe
Wei Shen cquark at gmail.com
Tue Sep 30 14:33:19 UTC 2008
Hi,
My patch should against which version?
 4.8.99.0 checked out by: "cvs -d
:pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems" ?
BR,
Wei
On 9/2/08, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Wei Shen wrote:
>> Hi all,
>> I think I am close to finishing my work on POSIX FIFO/pipe. I ported
>> the test cases in LTP (Linux Test Project) to test my code, seems that
>> all cases can be passed.
>> So, how can I submit my code?
> If the patch is small, you can post it to the list for others to see.
> But if it is too large, you can send it to me directly.
> Whether I merge it before or after making a 4.9 branch is unknown
> at this point.
>> Regards,
>> Wei
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
