ARM Initialization Question
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Sep 12 19:33:46 UTC 2008
Sebastian Huber wrote:
> Hi,
> I am quite new to the ARM architecture and try to develop a BSP for the
> LPC2478. I have a question to the initialization code (random start.S):
Just firing a warning shot .. I am starting to refactor out
more common code from the BSPs. Please try to help out
by moving with me to the better place. :)
+ You know about bsp_get_work_area. I am starting to
put it in "startup/bspgetworkarea.c" not bspstart.c
and reworking all BSPs to have one.
+ Once you have bsp_get_work_area, many BSPs no
longer need a bsp_pretasking_hook and can use
the common one.
+ I also want to review and consolidate bsp_cleanup
implementations. There are a lot of them that are
the same.
+ Eventually I want the bsp_pretasking_hooks to be in
their own file.
+ When all this much settles out, I can see the possibility
of some of the bsp_cleanup implementations referencing
bsp_reset(). I am also seeing how having bsp_spurious_initialize()
as a standard entry could simplify things.
I'm not picking on you personally just hoping that as new
BSPs get written and old ones updated, the authors help
out by using shared code from the framework where possible
and avoid duplicating more code.
> /* Set up the SVC stack pointer last and stay in SVC mode */
> mov r0, #(PSR_MODE_SVC | PSR_I | PSR_F) /* No interrupts */
> msr cpsr, r0
> ldr r1, =_svc_stack_size
> ldr sp, =_svc_stack
> add sp, sp, r1
> sub sp, sp, #0x64
> Why is 0x64 subtracted from the stack pointer?
> Sebastian Huber, Embedded Brains GmbH
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> PGP : Public key available on request
> rtems-users mailing list
> rtems-users at rtems.com
