Linking problem with libtelnetd
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Sep 15 13:49:31 UTC 2008
On Fri, 2008-09-12 at 18:00 +0200, Thomas Doerfler (nt) wrote:
> Tim,
> Tim Cussins schrieb:
> > powerpc-rtems4.9-gcc -B../../../../../virtex/lib/ -specs bsp_specs -qrtems -
> > mcpu=403 -Dppc405 -Dvirtex -O2 -g -fno-keep-inline-functions -mcpu=403 -
> > Dppc405 -Dvirtex -o hello.exe init.o ../../../../../virtex/lib/no-
> > barrier.rel ../../../../../virtex/lib/no-dpmem.rel
> > ../../../../../virtex/lib/no-event.rel ../../../../../virtex/lib/no-msg.rel
> > ../../../../../virtex/lib/no-mp.rel ../../../../../virtex/lib/no-part.rel
> > ../../../../../virtex/lib/no-region.rel ../../../../../virtex/lib/no-
> > signal.rel ../../../../../virtex/lib/no-timer.rel
> > ../../../../../virtex/lib/no-rtmon.rel ../../../../../virtex/lib/no-ext.rel
> I may be wrong, but I think you specify the path where ld should look
> for libraries,
The -B.. in the line above already implies this.
Ralf
