Make install problem with v4.8.0 on fedora9
Arquer Stephane stephane.arquer at c-s.cnes.fr
Mon Sep 22 14:57:25 UTC 2008
> Hello, Arquer,
> Are the RTEMS tools in your path (PATH environment variable)?
> Or, Are ALL RETMS tools installed?
Yes the PATH is correct, the tools are found and the make was done successfully.
The error occurs during the : sudo make install
> Note that "sparc-rtems4.8-ranlib" was not found.
> Att.
> Wendell P. Silva
> -----Mensagem original-----
> De: rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] Em nome de Arquer
> Stephane Enviada em: segunda-feira, 22 de setembro de 2008 11:49
> Para: rtems-users at rtems.com
> Assunto: Make install problem with v4.8.0 on fedora9
> Hello,
> I'm trying to compile rtems 4.8.0 on a fedora 9,  configure
> and make command succeeded but the make install break with
> the following error msg: ... Making install in libmd
> gmake[4]: entrant dans le répertoire «
/home/arquers/rtems/rtems-4.8.0/build/sparc-> rtems4.8/c/leon3/cpukit/libmd »
> gmake[5]: entrant dans le répertoire «
> gmake[5]: Rien à faire pour « install-exec-am ».
> gmake[5]: Rien à faire pour « install-data-am ».
> gmake[5]: quittant le répertoire «
> gmake[4]: quittant le répertoire «
/home/arquers/rtems/rtems-4.8.0/build/sparc-> rtems4.8/c/leon3/cpukit/libmd » Making install in wrapup
/home/arquers/rtems/rtems-4.8.0/build/sparc-> rtems4.8/c/leon3/cpukit/wrapup »
> test -z "/opt/rtems-4.8/sparc-rtems4.8/leon3/lib" ||
> /bin/mkdir -p "/opt/rtems-4.8/sparc-rtems4.8/leon3/lib"
>  /usr/bin/install -c -m 644 'librtemscpu.a'
> '/opt/rtems-4.8/sparc-rtems4.8/leon3/lib/librtemscpu.a'
> /bin/sh: line 4: sparc-rtems4.8-ranlib: command not found
> gmake[5]: *** [install-project_libLIBRARIES] Erreur 127
> gmake[4]: *** [install-am] Erreur 2
> gmake[3]: *** [install-recursive] Erreur 1
> gmake[3]: quittant le répertoire «
/home/arquers/rtems/rtems-4.8.0/build/sparc-> rtems4.8/c/leon3/cpukit »
> gmake[2]: *** [install-recursive] Erreur 1
> gmake[2]: quittant le répertoire «
/home/arquers/rtems/rtems-4.8.0/build/sparc-> rtems4.8/c/leon3 »
> gmake[1]: *** [install-recursive] Erreur 1
> gmake[1]: quittant le répertoire «
/home/arquers/rtems/rtems-4.8.0/build/sparc-> rtems4.8/c »
> make: *** [install-recursive] Erreur 1
> [arquers at localhost build]$
> Does anybody know this problem ?
> Thanks for help.
> Stephane.
> rtems-users mailing list
