Build Problem under Cygwin
Robert S. Grimes
rsg at alum.mit.edu
Fri Sep 26 15:22:19 UTC 2008
Okay, a hunch occurred to me after mailing this, so I'd like to ask a
different. question: how could I have gotten DOS end of lines into the
autoconf source?
Backing up a bit, I had used "tar xjf ../archive/autoconf-2.62.tar.bz2"
to unpack autoconf, like I've done many times before, so I certainly
assumed then EOL chars in text files would not be altered. (Note: Cygwin
has been installed to use Unix EOL - always has been on my machine).
However, something smelled fishy with the error, so in desperation, I
decided to run dos2unix on the autoconf-2.62 source tree, and lo and
behold, I was able to successfully configure, build, and install autoconf!
The RTEMS source tree is different, however. I again used tar, but this
time on a Linux machine, to unpack 4.9.0 and put it under revision
control (vendor branch under Subversion). Later, I checked it into my
Cygwin host and am attempting to build that. I'll have to figure out
where the DOS EOLs came from there...
So my questions now are these:
1. Any idea how I could have gotten DOS EOL chars into the autoconf
source tree?
2. Any idea how to test a tree for DOS EOL chars?
Thanks,
-Bob
Robert S. Grimes wrote:
> I'm trying to build the 4.9.0 toolset under Cygwin, and I'm not quite
> getting there. I have gotten binutils and gcc/newlib built, but I can't
> configure autoconf-2.62. Here is the output:
> $ ../autoconf-2.62/configure --prefix=/usr/rtems/4.9/bin
> checking for a BSD-compatible install... /usr/bin/ginstall -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> checking whether /bin/sh -n is known to work... yes
> checking for expr... /usr/bin/expr
> checking for GNU M4 that supports accurate traces... /usr/bin/m4
> checking how m4 supports trace files... --debugfile
> checking for perl... /usr/bin/perl
> checking for emacs... no
> checking for xemacs... no
> checking where .elc files should go... ${datadir}/emacs/site-lisp
> checking for grep that handles long lines and -e... /usr/bin/grep
> checking for egrep... /usr/bin/grep -E
> checking for a sed that does not truncate output... /usr/bin/sed
> configure: creating ./config.status
> config.status: creating tests/Makefile
> gawk: ./confd0FP0v/subs.awk:1: BEGIN {\r
> gawk: ./confd0FP0v/subs.awk:1: ^ backslash not last character
> on line
> config.status: error: could not create tests/Makefile
> But wait, there's more! I already have autoconf-2.61 installed, so I
> decided to hope that could work, and attempted to build RTEMS itself. I
> get the same failure - here is the relavent output:
> <snip>
> checking for bash... /usr/bin/bash
> config.status: creating Makefile
> gawk: ./confUm8h5X/subs.awk:1: BEGIN {\r
> gawk: ./confUm8h5X/subs.awk:1: ^ backslash not last character
> on line
> config.status: error: could not create Makefile
> configure: error: /bin/sh '../../../rtems/tools/build/configure'
> failed for tools/build
> Notice the similarity? I couldn't find anything with Google, primarily
> because I'm not sure what to specify to get good results - either no
> hits or way too many. I'm hoping someone can help here...
> Thanks,
> -Bob
> rtems-users mailing list
> rtems-users at rtems.com
