build rtems-4.8 error
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Sep 28 23:56:25 UTC 2008
Ralf Corsepius wrote:
> On Sun, 2008-09-28 at 11:59 +0800, 朱旭峰 wrote:
>> hi all:
>> I met following errors when I built rtems-4.8.The commands I
>> used were:
>> command: ../rtems-4.6.6-1.0.0/configure --target=sparc-rtems
>> gmake RTEMS_BSP="arc810"
>> errors:
>> sparc-rtems-gcc --pipe -DHAVE_CONFIG_H -I../../..
>> -I../../../../cpukit/../../../leon3/lib/include -Wall -fasm
>> -mcpu=cypress -msoft-float -O2 -g -MT libscorecpu_a-cpu.o -MD -MP
>> -MF .deps/libscorecpu_a-cpu.Tpo -c -o libscorecpu_a-cpu.o `test -f
>> 'cpu.c' || echo
>> '../../../../../../../../rtems-4.8/c/src/../../cpukit/score/cpu/sparc/'`cpu.c
>> In file included
>> from ../../../../../../leon3/lib/include/rtems/score/cpu.h:28,
>> from ../../../../../../leon3/lib/include/rtems/system.h:162,
>> from ../../../../../../../../rtems-4.8/cpukit/score/cpu/sparc/cpu.c:14:
>> ../../../../../../leon3/lib/include/rtems/score/types.h:34: syntax
>> error before "Priority_Bit_map_control"
>> ../../../../../../leon3/lib/include/rtems/score/types.h:34: warning:
>> type defaults to`int' in declaration of `Priority_Bit_map_control'
>> so,anyone can give some tips?
> Your toolchain is likely outdated or broken. It doesn't seem to support
> stdint.h
It seems very confused and out of date. The RTEMS
version indicates 4.6.6-1.0.0 and the sparc-rtems-gcc is reporting
something about rtems 4.8 in the messages.
This looks like Gaisler's 4.8 toolset binary and 4.6
RTEMS distribution. Definitely not a good match.
What is the arc810?
Any chance of updating to something recent with
standard RPMs for the binaries from rtems.org?
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
