config.sub generation bug?
ORMANCEY Nicolas
nicolas.ormancey at sogeti.com
Thu Apr 2 13:50:27 UTC 2009
Hi,
I'm porting RTEMS on an open source hypervisor.
And I'm developing the BSP for this "new hardware"
I decide to consider this hypervisor as a new CPU family.
So, by copy of sparc family and leon2 BSP I have generated and modified all
needed files (I hope so)
But when I launch the configure command it exit with the error "myCPUfamily"
not recognized
If in the congig.sub file I add "myCPUfamily" the configure command succeed.
So is it a bug or more probably I forget to add or modified a file. but
witch one.
Can you help me?
With a detailed procedure to add a CPU
Or
>From which files the config.sub is generated at boostrap time.
Thanks
Nicolas
Nicolas ORMANCEY
485, Avenue de L'Europe
38330 Montbonnot Saint Martin
04 76 52 66 38
URL: <http://lists.rtems.org/pipermail/users/attachments/20090402/d0e8304f/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090402/d0e8304f/attachment.jpg>
