config.sub generation bug?
Thu Apr 2 14:06:33 UTC 2009
ORMANCEY Nicolas wrote:
> Hi,
> I’m porting RTEMS on an open source hypervisor.
> And I’m developing the BSP for this “new hardware”
> I decide to consider this hypervisor as a new CPU family.
> So, by copy of sparc family and leon2 BSP I have generated and
> modified all needed files (I hope so)
> But when I launch the configure command it exit with the error
> “myCPUfamily” not recognized
$ ./config.sub joel-rtems4.10
Invalid configuration `joel-rtems4.10': machine `joel' not recognized
What exactly is the output from config.sub?
And if it doesn't give a message like above, what is the EXACT error
from configure.
Do you have a score/cpu directory yet? I don't recall the checks in
place because
I always copy stub files into a new cpu when I start and add it to the
configure.ac
and Makefile.am as appropriate. I like to have things compiling before I
hack.
Also it will eventually check for myCPUfamily-rtems4.10-gcc or whatever the
full target name is.  You need to address that with symlinks or something.
> If in the congig.sub file I add “myCPUfamily” the configure command
> succeed…
> So is it a bug or more probably I forget to add or modified a file…
> but witch one…
> Can you help me?
> With a detailed procedure to add a CPU
> Or
> From which files the config.sub is generated at boostrap time…
It isn't generated.
> Thanks
> Nicolas
> Nicolas ORMANCEY
> 485, Avenue de L’Europe
> 38330 Montbonnot Saint Martin
> 04 76 52 66 38
