linux/posix port compiling problem
Wei-Tsun Sun wsun013 at gmail.com
Wed Apr 8 03:08:14 UTC 2009
Hi,
I would like to know if anyone build RTEMS to run on i386-linux successfully ?
I have met problem like :
 - lack of machine/ansi.h : solved by build newlib for target=i386-linux-rtems
 - ...........cpukit/libmisc/shell/main_ls.c:513: error: ‘u_int64_t’ undeclared (first use in this function)
   This look bizzar
is there an existing patch to make the compilation work ?
Many thanks,
Wei-Tsun sun
