Trouble building 4.10 Makefile.in not found
Andrew Sporner
asporner at googlemail.com
Sun Apr 12 14:54:46 UTC 2009
Hi,
I am new to this and have following the quick-start on the documentation
page to the letter. I am running on Suse 11.1 and have installed the
development
tools from the rtems.com website.
I issue the command:
../rtems/configure --target=sparc-rtems4.10 --enable-rtemsbsp=sis
--enable-tests=samples --disable-posix -disable-itron
and after some time the output comes:
-------------SNIP BEGIN
running /bin/sh '../../../rtems/c/configure'
'--prefix=/opt/rtems-4.10' '--host=sparc-rtems4.10'
'--build=i686-suse-linux-gnu' '--target=sparc-rtems4.10'
'--enable-rtemsbsp=sis' '--enable-tests=samples' '--disable-posix'
'-disable-itron' '--with-target-subdir=sparc-rtems4.10'
'--exec-prefix=/opt/rtems-4.10/sparc-rtems4.10'
'--includedir=/opt/rtems-4.10/sparc-rtems4.10/include'
'--cache-file=/dev/null' '--srcdir=../../../rtems/c'
checking for gmake... gmake
checking for RTEMS Version... 4.9.99.0
checking build system type... i686-suse-linux-gnu
checking host system type... sparc-unknown-rtems4.10
checking target system type... sparc-unknown-rtems4.10
checking rtems target cpu... sparc
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking for sparc-rtems4.10-strip... no
checking for strip... strip
configure: WARNING: using cross tools not prefixed with host triplet
checking whether to enable maintainer-specific portions of Makefiles... no
checking for sis.cfg... ../../../rtems/c/../make/custom/sis.cfg
configure: creating ./config.status
config.status: creating Makefile
target architecture: sparc.
available BSPs: sis.
'gmake all' will build the following BSPs: sis.
other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
config.status: error: cannot find input file: Makefile.in
----------------- SNIP END
Any ideas?
Sincere regards
Andy
