Build now works, new failure.
Mon Apr 13 20:29:36 UTC 2009
Andrew Sporner wrote:
> I didn't reply to the list but the build problem has been solved.
> I can only guess it was something that got munged early on.  Starting complely
> from scratch resolved the problem.
> However there seems to be somthing new:
> During the build of the samples the fileio does not build.  The
> reported failure is:
> -- SNIP
> gmake[5]: Entering directory
> `/home/asporner/embedd/obj4.10/powerpc-rtems4.10/c/mpc8313erdb/testsuites/samples/fileio'
> powerpc-rtems4.10-gcc -B../../../../../mpc8313erdb/lib/ -specs
> bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
> -DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
> -DPACKAGE_VERSION=\"4.9.99.0\"
> -DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.9.99.0\"
> -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DSTDC_HEADERS=1
> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_INTTYPES_H=1
> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -I.
> -I../../../../../../../rtems-4.10/c/src/../../testsuites/samples/fileio
>     -mcpu=603e -mstrict-align -fno-strict-aliasing -meabi -msdata
> -fno-common -O2 -g -fno-keep-inline-functions -funit-at-a-time -W
> -Wno-unused -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o
> ../../../../../../../rtems-4.10/c/src/../../testsuites/samples/fileio/init.c
> mv -f .deps/init.Tpo .deps/init.Po
> bsp_specs -qrtems -mcpu=603e -mstrict-align -fno-strict-aliasing
> -meabi -msdata -fno-common -O2 -g -fno-keep-inline-functions
> -funit-at-a-time -W -Wno-unused   -qnolinkcmds -T linkcmds.mpc8313erdb
> -fno-common   -o fileio.exe init.o
> ../../../../../mpc8313erdb/lib/no-barrier.rel
> ../../../../../mpc8313erdb/lib/no-dpmem.rel
> ../../../../../mpc8313erdb/lib/no-event.rel
> ../../../../../mpc8313erdb/lib/no-mp.rel
> ../../../../../mpc8313erdb/lib/no-part.rel
> ../../../../../mpc8313erdb/lib/no-region.rel
> ../../../../../mpc8313erdb/lib/no-signal.rel
> ../../../../../mpc8313erdb/lib/no-timer.rel
> ../../../../../mpc8313erdb/lib/no-rtmon.rel
> ../../../../../mpc8313erdb/lib/no-ext.rel
> init.o: In function `fileio_start_shell':
> /home/asporner/embedd/obj4.10/powerpc-rtems4.10/c/mpc8313erdb/testsuites/samples/fileio/../../../../../../../rtems-4.10/c/src/../../testsuites/samples/fileio/init.c:188:
> undefined reference to `rtems_shell_login_check'
> init.o:(.data+0x264): undefined reference to `rtems_shell_HALT_Command'
> collect2: ld returned 1 exit status
> --- END SNIP
> Looking at the changelog I noticed that the HALT command was a new entry into
> the shell recently and wonder if all of the places where it has to be
> put made it.
Do you see libmisc/shell/main_halt.c getting built?
Do you see any mismatch in spelling grep'ing for halt in
libmisc/shell?  I don't and tested this.
I expected that it was missed in the Makefile.am but it is
there.
I just don't see it and there isn't much it could be.
> I was going to spend a few more hours pouring into this, but I think
> the person that
> wrote this probably would be a lot more efficient at this.
Subtle  hint. :)
> Many Thanks
> Andy
> On Sun, Apr 12, 2009 at 9:51 PM, Joel Sherrill
>>> Hi,
>>> I am new to this and have following the quick-start on the documentation
>>> page to the letter.  I am running on Suse 11.1 and have installed the
>>> development
>>> tools from the rtems.com website.
>>> I issue the command:
>>>  ../rtems/configure --target=sparc-rtems4.10 --enable-rtemsbsp=sis
>>> --enable-tests=samples --disable-posix -disable-itron
>>> and after some time the output comes:
>>> -------------SNIP BEGIN
>>> running /bin/sh '../../../rtems/c/configure'
>>> '--prefix=/opt/rtems-4.10' '--host=sparc-rtems4.10'
>>> '--build=i686-suse-linux-gnu' '--target=sparc-rtems4.10'
>>> '--enable-rtemsbsp=sis' '--enable-tests=samples' '--disable-posix'
>>> '-disable-itron' '--with-target-subdir=sparc-rtems4.10'
>>> '--exec-prefix=/opt/rtems-4.10/sparc-rtems4.10'
>>> '--includedir=/opt/rtems-4.10/sparc-rtems4.10/include'
>>> '--cache-file=/dev/null' '--srcdir=../../../rtems/c'
>>> checking for gmake... gmake
>>> checking for RTEMS Version... 4.9.99.0
>>> checking build system type... i686-suse-linux-gnu
>>> checking host system type... sparc-unknown-rtems4.10
>>> checking target system type... sparc-unknown-rtems4.10
>>> checking rtems target cpu... sparc
>>> checking for a BSD-compatible install... /usr/bin/install -c
>>> checking whether build environment is sane... yes
>>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>>> checking for gawk... gawk
>>> checking whether gmake sets $(MAKE)... yes
>>> checking for sparc-rtems4.10-strip... no
>>> checking for strip... strip
>>> configure: WARNING: using cross tools not prefixed with host triplet
>>> checking whether to enable maintainer-specific portions of Makefiles... no
>>> checking for sis.cfg... ../../../rtems/c/../make/custom/sis.cfg
>>> configure: creating ./config.status
>>> config.status: creating Makefile
>>> target architecture: sparc.
>>> available BSPs: sis.
>>> 'gmake all' will build the following BSPs: sis.
>>> other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
>>> config.status: error: cannot find input file: Makefile.in
>>> ----------------- SNIP END
>>> Any ideas?
>> Did you load the rtems autoconf and automake?  It is at the
>> head of your PATH?  Did you run "bootstrap" from the top
>> of the RTEMS source tree?
>> in the above is a big hint that something isn't right in your
>> PATH?
>> --joel
>>> Sincere regards
>>> Andy
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
