linux/posix port compiling problem
Tue Apr 14 22:03:23 UTC 2009
Ralf Corsepius wrote:
> Joel Sherrill wrote:
>> Looking at the patch, it looks like it boils down to 3 things:
>> + disable shell for posix port (easier to drop it from building at all).
> Well, rtems shell got infected with with newlib-proprietary,
> non-portable construct.
Is this the getopt_r call you are referring too ?
> IMO, we should get rid of them and either re-write the code or abandon it.
I do not know what code you are referring to here, shell, linux-posix BSP or
something else ?
>> + use *.o on command line instead of from file with ar (why?)
> IMO, this patch doesn't make much sense.
>> + a small patch to provide a malloc initialize stub.
> This is a real bug in RTEMS.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
