Mingw and PSIM build
Somervill, Kevin M. (LARC-D203) kevin.m.somervill at nasa.gov
Wed Apr 15 16:04:44 UTC 2009
Hello,
I'm trying to build powerpc/psim bsp in mingw and having some build issues.  I can build the sparc/sis bsp and run the ticker and hello examples.
I followed mingw install process on the wiki for rtems 4.9 and the 4.9.2 source.
I use the following configure command:
$ ../rtems-4.9.2/configure --target=powerpc-rtems4.9 --enable-rtemsbsp=psim --enable-posix --enable-cxx --enable-tests=samples
Issuing make I get the following error:
powerpc-rtems4.9-gcc --pipe -B../../../lib/ -B../../../psim/lib/ -specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src\" -DPACKAGE_TARNAME=\"rtems-c-src\" -DPACKAGE_VERSION=\"4.9.2\" -DPACKAGE_STRING=\"rtems-c-src\ 4.9.2\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -I. -I../../../../../rtems-4.9.2/c/src/libchip  -I../../../psim/lib/include -D__INSIDE_RTEMS_BSD_TCPIP_STACK__  -Wall -pipe -O2 -MT network/libnetchip_a-dec21140.o -MD -MP -MF network/.deps/libnetchip_a-dec21140.Tpo -c -o network/libnetchip_a-dec21140.o `test -f 'network/dec21140.c' || echo  '../../../../../rtems-4.9.2/c/src/libchip/'`network/dec21140.c
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c: In function 'dec21140IsOn':
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:347: warning: implicit declaration of function 'BSP_irq_enabled_at_i8259s'
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c: In function 'dec21140Enet_initialize_hardware':
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:455: error: 'PCI_DRAM_OFFSET' undeclared (first use in this function)
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:455: error: (Each undeclared identifier is reported only once
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:455: error: for each function it appears in.)
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c: In function 'dec21140_rxDaemon':
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:605: error: 'PCI_DRAM_OFFSET' undeclared (first use in this function)
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c: In function 'sendpacket':
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:645: error: 'PCI_DRAM_OFFSET' undeclared (first use in this function)
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c: In function 'rtems_dec21140_driver_attach':
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:998: error: 'PCI_MEM_BASE' undeclared (first use in this function)
../../../../../rtems-4.9.2/c/src/libchip/network/dec21140.c:1000: warning: assignment from incompatible pointer type
make[3]: *** [network/libnetchip_a-dec21140.o] Error 1
make[3]: Leaving directory `/home/ksomervi/rtems/b-psim/powerpc-rtems4.9/c/psim/libchip'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/ksomervi/rtems/b-psim/powerpc-rtems4.9/c/psim'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/ksomervi/rtems/b-psim/powerpc-rtems4.9/c'
make: *** [all-recursive] Error 1
In dec21140.c both bsp.h and and libcpu/io.h are included.  In the io.h, it says that PCI_DRAM_OFFSET is now defined in bsp.h, but this isn't in the psim/include/bsp.h  How is PCI_DRAM_OFFSET to be pulled in?  The other bsps seem to redefine the PREP_PCI_DRAM_OFFSET or CHRP_PCI_DRM_OFFSET and I can't find this for the psim bsp.  I can build the haleakala bsp, but I can't build the coldfire mcf206elite bsp (only hardware I have on hand and I was hoping to play with it). Any suggestions?  Should I suspect my build environment?  I'm new to RTEMS and I'm hoping to fiddle my way through porting to the embedded planet ep405pc board.  Hoping to use the haleakala as a starting point. I want to make sure I've got a sain environment and get familiar first.
Thanks,
./ks
Kevin Somervill:757-864-6570:Computer Engineer:NASA/LaRC/SED/ESB
  - There's no such thing as beginner's luck...
