Has anyone ponied up to the update of TCP/IP yet?
xu ray rayx.cn at gmail.com
Thu Apr 16 09:11:27 UTC 2009
I think the only reason usb from FreeBSD better than NetBSD might be
the compatibly with TCP/IP (rtems is using Freebsd).
NetBSD is the first to have USB stack in all bsd family and FreeBSD
just ported NetBSD's stack to itself and all BSD family synicronize
usb codes from each other from that time. So it hard to say which code
base is more advanced.
The advantage of NetBSD stack is its support for different families.
The USB support for ARM and PPC families has long been merged into
release branches. However, there are no support for other
architectures in Freebsd in release branch so far (at91rm9200 still on
dev branch). I think the different arch support will also be a problem
that we will face when porting Freebsd TCP/IP from FreeBSD to RTEMS.
In short, porting from both OSes have their advantages and drawbacks.
2009/4/16 Thomas Dörfler <Thomas.Doerfler at imd-systems.de>:
> Hi,
> sorry for being silent on that issue (USB) for so long. We have received
> your USB port package and after some inspection came to the conclusion
> that in the long term it would be better to port the USB functinality
> from FreeBSD to RTEMS, but with a more complete "FreeBSD porting layer".
> The benefits from that approach are:
> - have a more modern USB stack (which may even include client functinality)
> - have the capability to upgrade to newer FreeBSD packages with low effort
> - have the capability to upgrade the TCP/IP stack with low effort
> - keep much closer to the FreeBSD sources WRT these two stacks and their
> drivers
> This work is already in progress.
> wkr,
> Thomas Doerfler.
> xu ray wrote:
>> No one has claimed as a mentor for this project yet.
>> However, my friend and I are on the way to merge the USB stack from
>> NetBSD now. We choose NetBSD because it is more friendly to different
>> architectures.
>> If you will begin to merge the new BSD TCP/IP. I think it will be a
>> good idea to work together because there are lots of common codes
>> (esp, the BSD header file and the OS adaptor layer)
>> 2009/4/14 Andrew Sporner <asporner at googlemail.com>:
>>> I am curious if this "open task" has been claimed.
>>> If not I would be eager to take it on.  I have been working in the TCP/IP
>>> area for about 10 years now and know the FreeBSD stack fairly well
>>> (as well as that kernel fairly well).
>>> Cheers
>>> Andy
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>     http://www.imd-systems.de/pgpkey_en.html
Thanks & Best Regards!
Ray, Xu
