RTEMS compilation problem
lukasz mosdorf lukasz.mosdorf at gmail.com
Mon Apr 27 15:13:46 UTC 2009
Hi all.
I'm new to the RTEMS and have already encountered some problems just at
a very beginning - Im stuck :(. I tried to compile rtems 4.9 for powerpc
bsp virtex. I get the following errors:
Making all in src/nfsclient
gmake[6]: Entering directory
`/home/mort/RTEMS_CVS/b-ppc/powerpc-rtems4.9/c/virtex/cpukit/libfs/src/nfsclient'
powerpc-rtems4.9-gcc --pipe -DHAVE_CONFIG_H   -I../../..
-I../../../../cpukit/../../../virtex/lib/include
-I../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/proto
-UHAVE_CEXP
-UHAVE_CEXP  -Wall -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -fasm -mcpu=403 -Dppc405 -O2 -g
-fno-keep-inline-functions -MT src/libnfs_a-rpcio.o -MD -MP -MF
src/.deps/libnfs_a-rpcio.Tpo -c -o src/libnfs_a-rpcio.o `test -f
'src/rpcio.c' || echo
'../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/'`src/rpcio.c
mv -f src/.deps/libnfs_a-rpcio.Tpo src/.deps/libnfs_a-rpcio.Po
-UHAVE_CEXP
-fno-keep-inline-functions -MT src/libnfs_a-nfs.o -MD -MP -MF
src/.deps/libnfs_a-nfs.Tpo -c -o src/libnfs_a-nfs.o `test -f 'src/nfs.c'
|| echo
'../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/'`src/nfs.c
mv -f src/.deps/libnfs_a-nfs.Tpo src/.deps/libnfs_a-nfs.Po
-UHAVE_CEXP
-fno-keep-inline-functions -MT src/libnfs_a-sock_mbuf.o -MD -MP -MF
src/.deps/libnfs_a-sock_mbuf.Tpo -c -o src/libnfs_a-sock_mbuf.o `test -f
'src/sock_mbuf.c' || echo
'../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/'`src/sock_mbuf.c
../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/src/sock_mbuf.c:
In function 'recv_mbuf_from':
../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/src/sock_mbuf.c:228:
error: storage size of 'auio' isn't known
warning: unused variable 'auio'
gmake[6]: *** [src/libnfs_a-sock_mbuf.o] Error 1
gmake[6]: Leaving directory
gmake[5]: *** [all-recursive] Error 1
gmake[5]: Leaving directory
`/home/mort/RTEMS_CVS/b-ppc/powerpc-rtems4.9/c/virtex/cpukit/libfs'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/home/mort/RTEMS_CVS/b-ppc/powerpc-rtems4.9/c/virtex/cpukit'
gmake[3]: *** [all] Error 2
gmake[3]: Leaving directory
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/mort/RTEMS_CVS/b-ppc/powerpc-rtems4.9/c/virtex'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/mort/RTEMS_CVS/b-ppc/powerpc-rtems4.9/c'
gmake: *** [all-recursive] Error 1
i did run he following configuration:
 ../rtems/configure --target=powerpc-rtems4.9 --enable-rtemsbsp=virtex
--enable-tests=samples --prefix=/opt/rtems-4.9/
I got the crosscompiler from rpm's for fedora 10.
Any ideas how to fix it?
