RTEMS 4.9.1 GDB
Randall, Mark
mr63 at evansville.edu
Mon Apr 27 17:46:13 UTC 2009
OK I am able to debug using GDB when I enable the Qemu debug server
using the -s option and use the localhost:1234 as the target.
However although this works This is really not what I am trying to
accomplish. I would like to run the GDB server on my RTEMS application
as
If I was running it on a actual hardware target. As I said before I
would like to use a TCP connection and not the serial port. Can anyone
help me out?
Thanks ,
Mark
URL: <http://lists.rtems.org/pipermail/users/attachments/20090427/4f4fe74b/attachment.html>
