rtems samples crash
lukasz mosdorf
lukasz.mosdorf at gmail.com
Thu Apr 30 09:27:30 UTC 2009
Hi all,
I have compiled RTEMS 4.9 for powerpc bsp virtex. Unfortunatelly Im not
able to run example programs. I do the following thing:
[root at mort RTEMS_CVS]# powerpc-rtems4.9-gdb `find . -name ticker.exe`
GNU gdb 6.8
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu
--target=powerpc-rtems4.9"...
(gdb) tar sim
Connected to the simulator.
(gdb) load
(gdb) r
Starting program:
/home/mort/RTEMS_CVS/b-mpc55xxevb/powerpc-rtems4.9/c/virtex/testsuites/samples/ticker/ticker.exe
core_find_mapping() - access to unmaped address, attach a default map to
handle this - addr=0x40600008 nr_bytes=0x4 processor=0xb7c92008 cia=0x13414
i did a stack trace and it looks like printing to a console crashes:
(gdb) bt
#0 outputChar (ch=85 'U')
at
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/console/consolelite.c:67
#1 0x0001561c in vprintk (
fmt=0x2f380 "Unknown PVR value of 0x%x. Please add it to
<libcpu/powerpc/shared/include/cpuIdent.c>\n", ap=0x3ff74)
at
../../../../../../rtems/c/src/../../cpukit/libcsupport/src/printk.c:159
#2 0x0001593c in printk (fmt=<value optimized out>)
at
../../../../../../rtems/c/src/../../cpukit/libcsupport/src/printk.c:174
#3 0x00013cf0 in get_ppc_cpu_type ()
at
../../../../../../../rtems/c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c:111
#4 0x00013108 in bsp_start ()
at
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c:163
#5 0x00013000 in boot_card (argc=<value optimized out>,
argv=<value optimized out>, envp=<value optimized out>)
at
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/../../shared/bootcard.c:197
#6 0x00010024 in .startup ()
at
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/dlentry/dlentry.S:106
Backtrace stopped: previous frame inner to this frame (corrupt stack?)
Same thing happens with all examples, not only this one.
Any ideas ?
regards
Lukasz Mosdorf
