rtems samples crash
Thu Apr 30 11:15:58 UTC 2009
Tim Cussins wrote:
> Hi Lukasz,
> Instead of invoking gdb directly, Joel has written some wrapper scripts
> that setup the psim simulator correctly. Look for 'psim', 'psim-gdb',
> and 'runtests' - I think they get installed to the tests directory.
But he is running the virtex BSP which won't run on the
ppc simulator in gdb.  You have to be running psim executables
and invoking gdb requires a lot of arguments for psim.  You
need to use the scripts Tim mentioned PLUS the right BSP.
--joel
> HTH
> Tim
> On Thu, 30 Apr 2009 11:27 +0200, "lukasz mosdorf"
> <lukasz.mosdorf at gmail.com> wrote:
>> Hi all,
>> I have compiled RTEMS 4.9 for powerpc bsp virtex. Unfortunatelly Im not
>> able to run example programs. I do the following thing:
>> [root at mort RTEMS_CVS]# powerpc-rtems4.9-gdb `find . -name ticker.exe`
>> GNU gdb 6.8
>> Copyright (C) 2008 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later
>> <http://gnu.org/licenses/gpl.html>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law.  Type "show
>> copying"
>> and "show warranty" for details.
>> This GDB was configured as "--host=i686-pc-linux-gnu
>> --target=powerpc-rtems4.9"...
>> (gdb) tar sim
>> Connected to the simulator.
>> (gdb) load
>> (gdb) r
>> Starting program:
>> /home/mort/RTEMS_CVS/b-mpc55xxevb/powerpc-rtems4.9/c/virtex/testsuites/samples/ticker/ticker.exe
>> core_find_mapping() - access to unmaped address, attach a default map to
>> handle this - addr=0x40600008 nr_bytes=0x4 processor=0xb7c92008
>> cia=0x13414
>> i did a stack trace and it looks like printing to a console crashes:
>> (gdb) bt
>> #0  outputChar (ch=85 'U')
>>     at
>> ../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/console/consolelite.c:67
>> #1  0x0001561c in vprintk (
>>     fmt=0x2f380 "Unknown PVR value of 0x%x. Please add it to
>> <libcpu/powerpc/shared/include/cpuIdent.c>\n", ap=0x3ff74)
>>     at
>> ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/printk.c:159
>> #2  0x0001593c in printk (fmt=<value optimized out>)
>>     at
>> ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/printk.c:174
>> #3  0x00013cf0 in get_ppc_cpu_type ()
>>     at
>> ../../../../../../../rtems/c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c:111
>> #4  0x00013108 in bsp_start ()
>>     at
>> ../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c:163
>> #5  0x00013000 in boot_card (argc=<value optimized out>,
>>     argv=<value optimized out>, envp=<value optimized out>)
>>     at
>> ../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/../../shared/bootcard.c:197
>> #6  0x00010024 in .startup ()
>>     at
>> ../../../../../../../../rtems/c/src/lib/libbsp/powerpc/virtex/dlentry/dlentry.S:106
>> Backtrace stopped: previous frame inner to this frame (corrupt stack?)
>> Same thing happens with all examples, not only this one.
>> Any ideas ?
>> regards
>> Lukasz Mosdorf
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
