linux/posix port compiling problem
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 8 13:22:54 UTC 2009
Wei-Tsun Sun wrote:
> Hi,
>> Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>>> is there an existing patch to make the compilation work ?
>> No. I think, we should face the unpleasant truth: The unix/posix BSP is
>> dead.
> I have done some modifications here and there and finally the code compiled and linked. Helloworld works fine.
Submit the patches and let's move from there. Which distribution
and version?
> Ticker only have 2 tasks active although they both stop at 35 seconds.
That sounds like correct behaviour if you ignore the error below.
> Creation of task 3 returned a error code of
> 14 (I guess this can be obtained from errno.h: #define EFAULT 14 /* Bad address */)........
No. The error codes in the Classic API are defined in
cpukit/rtems/include/rtems/rtems/status.h.
* This is the status to indicate that a thread is in wrong state
* was in the wrong execution state for the requested operation.
RTEMS_INCORRECT_STATE = 14,
> Just wondering for previous success examples, did they use newlib or native libc ?
Native libc which limited the functionality that could work. It was
developed before the POSIX API was implemented and CPU simulators
were hard to come by.
> Willie
> rtems-users mailing list
> rtems-users at rtems.com
