Mingw and PSIM build
Somervill, Kevin M. (LARC-D203)
kevin.m.somervill at nasa.gov
Mon Apr 20 14:52:31 UTC 2009
Hi Sebastian,
| From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
| I can build this BSP without any problems on MinGW. My guess
| is that CFLAGS is set in your MinGW shell environment. This
| prevents the configure to use its pre-defined (and in most
| cases appropriate) values.
You are the man. My environment CFLAGS was trumping the build process additions to the variable. Is that normal? I thought the make process defaulted to internal variable definition that would be added to environmental variable, hence the "--environment-overrides" flag to make the environmental variable set the value. Any ways, it now works.
Thanks much,
./ks
