Thread Dispatch via Interrupts
Chris Johns
chrisj at rtems.org
Wed Apr 29 10:51:20 UTC 2009
Sebastian Huber wrote:
> Hi,
> a common task of interrupt handlers is to do a thread dispatch after the actual
> interrupt processing. On many architectures this is done in assembler code
> which lead recently to problems due to a data type size change, see also
> https://www.rtems.org/bugzilla/show_bug.cgi?id=1385
> On PowerPC we where not affected by this kind of problems, since we use this:
> void _ISR_Thread_dispatch(void)
> if (_Context_Switch_necessary) {
> _Thread_Dispatch();
> } else if (_ISR_Signals_to_thread_executing) {
> _ISR_Signals_to_thread_executing = false;
> if (
> _Thread_Do_post_task_switch_extension
> || _Thread_Executing->do_post_task_switch_extension
> _Thread_Executing->do_post_task_switch_extension = false;
> _API_extensions_Run_postswitch();
> We should add this or a similar function to the super core.
> The ARM and m68k for example the thread dispatch is not done in this way. Is
> there a reason for this?
The code you provided is not the same logic as the m68k. It does not handle
_Thread_Do_post_task_switch_extension. I wonder if it should.
Where do the stacks get managed in the C version ?
The m68k has a range of different stack hardware to support. The Coldfire
supports stack switching in the ISR, the 68020 and similar devices support
separate stacks and require a dummy stack frame be inserted into the ISR's
stack so the return from interrupt returns the task's stack where
_Thread_dispatch is called.
It is nice to see gcc and hand coded assembler almost agree on the
instructions each uses.
Regards
> Have a nice day!
