questions to spfatal07 and unlimited tests
Thu Aug 20 15:05:49 UTC 2009
Christian Mauderer wrote:
> Than you for your informative answer. Now I know a little bit more :-)
> I have got a remark to another test:
> By running the sp20-test, it seems that the periods for the tasks are to
> short to print the full text on a 115200 bps serial link. I had to set
> them higher to run the test successfully.
> The original definition in the task1.c was:
> uint32_t      Periods[7]    = { 0,   2,   2,   2,   2, 100, 0 };
> I have multiplied all times by 10 to run the test and got the following
> line:
> uint32_t      Periods[7]    = { 0,   20,   20,   20,   20, 1000, 0 };
Did that impact the total run-time?
Or the iteration totals?
> Kind regards,
> Christian Mauderer
