Réf : Re: RTEMS LEON2 EDAC Trap Management
Leonard Bise
leonard.bise at syderal.ch
Wed Dec 2 06:59:09 UTC 2009
Thank you Aleix! But yeah I'm working on uncorrectable EDAC errors.
Also I was wondering, the trap table is installed using this function,
maybe this could be the cause of my problem?
void OS_install_handler(OS_FUNCPTR handler, uint32 irq) {
/*#[ operation OS_install_handler(OS_FUNCPTR,uint32) */
set_vector ((const rtems_isr_entry) handler, irq, 1);
Aleix Conchillo Flaqué <aconchillo at ice.csic.es>
Envoyé par : aconchillo at gmail.com
01.12.2009 19:43
A
Leonard Bise <leonard.bise at syderal.ch>
cc
rtems-users at rtems.org
Objet
Sorry Leonard, I just read your mail too fast. May be my answer helps
someone else with single errors. :-)
Cheers,
Aleix
On Tue, Dec 1, 2009 at 17:24, Leonard Bise <leonard.bise at syderal.ch>
wrote:
> Hi all,
> I'm working on an RTEMS application running on a LEON2 processor.
> I have some issues in regard to the Double EDAC error trap (0x09)
> management.
> I'm trying to validate that my application correctly manages EDAC errors
by
> launching my application, breaking then generating an EDAC error and
then
> resuming.
> My application then detects that an error has hapened and launches the
> correct trap handler.
> After the trap has been handled, we resume normal execution by executing
the
> rett instruction (return from trap), with the address of the next
> instruction after the one that has been trapped.
> Only that instead of continuing executing after the rett, the same
> instruction that triggered the first error triggers another error (0x11)
> which should be a correctable EDAC error.
> This behavior then loops forever (Double EDAC than Single EDAC etc...)
and
> after some time my application resets (I have approximatively 32'000
trap
> triggered for each one before it resets).
> I've been looking around for help in the LEON "community" but I could
not
> find much help. I know it is not necessarily RTEMS related but a
colleague
> of mine which does the exact same thing on another project but only in C
has
> no problem so I'm wondering what might be causing this.
> For info here is my double edac trap handler.
> static void BGD_trap_DE_handler(void) {
> /*#[ operation BGD_trap_DE_handler() */
> volatile uint32* failing_address;
> boolean accepted = FALSE;
> /* read Failure Address Register */
> asm("TEST_EDAC_DOUBLE_START:nop;");
> failing_address = *FAILAR;
> FIFO_edac_address [FIFO_edac_next] = (uint32)failing_address;
> FIFO_edac_double [FIFO_edac_next] = 1;
> FIFO_edac_nb = (FIFO_edac_nb & 0xF) + 1;
> /* Note: in case more than 16 errors occur during 1 second, the
16
> oldest will be lost. */
> FIFO_edac_next = (FIFO_edac_next+1) & 0xF;
> /* SYD MOD */
> if ((failing_address < START_EEPROM) || (failing_address >=
> 0x80000000))
> BGD_process_d_edac_sram();
> else
> BGD_process_d_edac_eeprom();
> /* reset fail status register */
> *FAILSR = 0;
> *FAILAR = 0;
> //BDT_abort_request (&accepted);
> asm("TEST_EDAC_DOUBLE_END:nop;");
> Here is a disassembly of the instruction that triggers the Double EDAC
> Trap, which is correct:
> 1046115464 40001400 cmp %i0, 15 [00000ff1]
> 1046115466 40001404 bgu 0x40001414 [00000000]
> 1046115467 40001408 nop [00000000]
> 1046115468 40001414 add %fp, -20, %i5 [401e5f34]
> 1046115473 ahb read, mst=0, size=2 [401e5f34 40053854]
> 1046115474 40001418 ld [%i5], %i2 [40053854]
> 1046115475 4000141c add %fp, -24, %i4 [401e5f30]
> 1046115480 ahb read, mst=0, size=2 [401e5f30 40100000]
> 1046115481 40001420 ld [%i4], %i1 [40100000]
> 1046115482 40001424 mov %i2, %i3 [40053854]
> 1046115483 40001428 mov %i1, %i0 [40100000]
> 1046115491 ahb read, mst=0, size=2 [40100000 a6102003]
> 1046115492 4000142c ld [%i0], %i0 [trapped]
> Here is the second trap triggered, which should not happen:
> 1046117903 4002bdc8 mov %l0, %psr [000000c4]
> 1046117904 4002bdcc nop [00000000]
> 1046117905 4002bdd0 nop [00000000]
> 1046117906 4002bdd4 nop [00000000]
> 1046117911 ahb read, mst=0, size=2 [401e5e84 00000000]
> 1046117912 4002bdd8 ld [%g1 + 0x6c], %g1 [00000000]
> 1046117913 4002bddc jmp %l1 [4002bddc]
> 1046117914 4002bde0 rett %l2 [40001430]
> 1046117916 4000142c ld [%i0], %i0 [trapped]
> I hope someone can help ;)
> Léonard.
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20091202/1f8057ee/attachment.html>
