Réf : Re: Réf : Re: Réf : Re: Init of the memory by RTEMS
Leonard Bise
leonard.bise at syderal.ch
Thu Dec 10 07:37:57 UTC 2009
I tried this methode but surprinsingly the memory in this area STILL gets
erased. I don't know by what and it does not make any sense either.
401e0000 g *ABS* 00000000 _RAM_END
That seems correct but something is STILL clearing that damn memory !
I'm seriously lost now..
Léonard.
Joel Sherrill <joel.sherrill at oarcorp.com>
09.12.2009 20:28
A
Aleix Conchillo Flaqué <aconchillo at ice.csic.es>
cc
Leonard Bise <leonard.bise at syderal.ch>, "rtems-users at rtems.org"
<rtems-users at rtems.org>
Objet
On 12/09/2009 10:24 AM, Aleix Conchillo Flaqué wrote:
> Why don't you just change the start of your Application? For example:
> MEMORY
> ram : ORIGIN = 0x40020000, LENGTH = 2M - 128 K
> RTEMS will not modify anything from 0x40000000 to 0x4001FFFF.
Or simply leave ORIGIN alone and subtract 128K from the LENGTH.
Either way works. But you can't tell RTEMS about it. :)
--joel
> On Wed, Dec 9, 2009 at 14:26, Leonard Bise <leonard.bise at syderal.ch
> <mailto:leonard.bise at syderal.ch>> wrote:
> Thanks for your answer Joel.
> We are using the 4.6 version of RTEMS so I guess the memory must
> be cleared.
> I already use a customized linkcmds file in this application, to
> specify various sections and other stuff.
> Thats what I modified for my RAM size :
> RAM_SIZE = 2M ;
> EEPROM_SIZe = 512K ;
> PROM_SIZE = 64K ;
> RAM_END = RAM_START + RAM_SIZE;
> MEMORY
> rom : ORIGIN = 0x00000000, LENGTH = 64K
> ram : ORIGIN = 0x40000000, LENGTH = 2M
> eeprom : ORIGIN = 0x60000000, LENGTH = 512K
> >If you do not reserve the memory area out of the linkcmds, then
> >it is likely to be used for some other purpose and overwritten.
> How can I reserve memory ? I tried creating a section like this :
> sCCA_Main 0x401E7000: {
> *(sCCA_Main)
> } > ram
> then my var in the code looks like this :
> uint32 PkgHW_CCA_main __attribute__ (( section ( "sCCA_Main" ) ) ) ;
> But this does not work, the data I place in 0x401E7000 before
> starting execution of my RTEMS apps is overwritten by 0.
> Hope you can help.
> Léonard.
> *Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>>*
> 09.12.2009 14:16
> A
> cc
> Sebastian Huber <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>,
> "rtems-users at rtems.org <mailto:rtems-users at rtems.org>"
> <rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
> Objet
> On 12/09/2009 06:41 AM, Leonard Bise wrote:
> > I forgot to mention it.
> > I'm using RTEMS for the LEON2 platform.
> Version?
> > Also I'm not too sure how to know the address of the workspace
> or heap?
> They are next to each other and the linkcmds and symbol
> table from your application should give the information.
> Where did you override the RAM size? The linkcmds
> has this:
> MEMORY
> rom : ORIGIN = 0x00000000, LENGTH = 256M
> ram : ORIGIN = 0x40000000, LENGTH = 1024M
> And the start.S zeroes out the BSS from "_edata"
> to "_end".
> The addresses you mentioned will be part of the
> unused memory from after the bss until the end of ram
> and since you didn't tell the linkcmds or RTEMS about them,
> they will be put in either the Workspace or C Program Heap
> and used by something.
> --joel
> > Léonard.
> > *Sebastian Huber <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>*
> > 09.12.2009 11:31
> > A
> > cc
> > Objet
> > Hi,
> > which BSP do you use? Is the memory address 0x401E7000 part of the
> > workspace or
> > heap?
> > CU
> > Sebastian Huber, embedded brains GmbH
> > Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> > Phone : +49 89 18 90 80 79-6
> > Fax : +49 89 18 90 80 79-9
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> EHUG.
> rtems-users mailing list
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20091210/94468bf7/attachment-0001.html>
