Init of the memory by RTEMS
Jiri Gaisler
jiri at gaisler.com
Thu Dec 10 13:15:53 UTC 2009
grmon does not clear memory, unless you do the 'wash' command.
The simplest way to find our what happens is to put a data
watchpoint on this address and see where it is hit ...
Jiri.
Joel Sherrill wrote:
> On 12/10/2009 01:37 AM, Leonard Bise wrote:
>> I tried this methode but surprinsingly the memory in this area STILL
>> gets erased. I don't know by what and it does not make any sense either.
>> 401e0000 g *ABS* 00000000 _RAM_END
>> That seems correct but something is STILL clearing that damn memory !
> Are you doing a CPU reset?
> Do you have GRMON? I think it clears memory also.
>> I'm seriously lost now..
>> Léonard.
>> *Joel Sherrill <joel.sherrill at oarcorp.com>*
>> 09.12.2009 20:28
>> A
>> Aleix Conchillo Flaqué <aconchillo at ice.csic.es>
>> cc
>> Leonard Bise <leonard.bise at syderal.ch>, "rtems-users at rtems.org"
>> <rtems-users at rtems.org>
>> Objet
>> Re: Réf : Re: Réf : Re: Init of the memory by RTEMS
>> On 12/09/2009 10:24 AM, Aleix Conchillo Flaqué wrote:
>> > Why don't you just change the start of your Application? For example:
>> > MEMORY
>> > ram : ORIGIN = 0x40020000, LENGTH = 2M - 128 K
>> > RTEMS will not modify anything from 0x40000000 to 0x4001FFFF.
>> Or simply leave ORIGIN alone and subtract 128K from the LENGTH.
>> Either way works. But you can't tell RTEMS about it. :)
>> --joel
>> > On Wed, Dec 9, 2009 at 14:26, Leonard Bise <leonard.bise at syderal.ch
>> > <mailto:leonard.bise at syderal.ch>> wrote:
>> > Thanks for your answer Joel.
>> > We are using the 4.6 version of RTEMS so I guess the memory must
>> > be cleared.
>> > I already use a customized linkcmds file in this application, to
>> > specify various sections and other stuff.
>> > Thats what I modified for my RAM size :
>> > RAM_SIZE = 2M ;
>> > EEPROM_SIZe = 512K ;
>> > PROM_SIZE = 64K ;
>> > RAM_END = RAM_START + RAM_SIZE;
>> > MEMORY
>> > rom : ORIGIN = 0x00000000, LENGTH = 64K
>> > ram : ORIGIN = 0x40000000, LENGTH = 2M
>> > eeprom : ORIGIN = 0x60000000, LENGTH = 512K
>> > >If you do not reserve the memory area out of the linkcmds, then
>> > >it is likely to be used for some other purpose and overwritten.
>> > How can I reserve memory ? I tried creating a section like this :
>> > sCCA_Main 0x401E7000: {
>> > *(sCCA_Main)
>> > } > ram
>> > then my var in the code looks like this :
>> > uint32 PkgHW_CCA_main __attribute__ (( section ( "sCCA_Main" ) )
>> > But this does not work, the data I place in 0x401E7000 before
>> > starting execution of my RTEMS apps is overwritten by 0.
>> > Hope you can help.
>> > Léonard.
>> > <mailto:joel.sherrill at oarcorp.com>>*
>> > 09.12.2009 14:16
>> > A
>> > cc
>> > Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> > <mailto:sebastian.huber at embedded-brains.de>>,
>> > "rtems-users at rtems.org <mailto:rtems-users at rtems.org>"
>> > <rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>> > Objet
>> > On 12/09/2009 06:41 AM, Leonard Bise wrote:
>> > > I forgot to mention it.
>> > > I'm using RTEMS for the LEON2 platform.
>> > Version?
>> > > Also I'm not too sure how to know the address of the workspace
>> > or heap?
>> > They are next to each other and the linkcmds and symbol
>> > table from your application should give the information.
>> > Where did you override the RAM size? The linkcmds
>> > has this:
>> > MEMORY
>> > rom : ORIGIN = 0x00000000, LENGTH = 256M
>> > ram : ORIGIN = 0x40000000, LENGTH = 1024M
>> > And the start.S zeroes out the BSS from "_edata"
>> > to "_end".
>> > The addresses you mentioned will be part of the
>> > unused memory from after the bss until the end of ram
>> > and since you didn't tell the linkcmds or RTEMS about them,
>> > they will be put in either the Workspace or C Program Heap
>> > and used by something.
>> > --joel
>> > > Léonard.
>> > > *Sebastian Huber <sebastian.huber at embedded-brains.de
>> > <mailto:sebastian.huber at embedded-brains.de>>*
>> > > 09.12.2009 11:31
>> > > A
>> > > cc
>> > > Objet
>> > > Hi,
>> > > which BSP do you use? Is the memory address 0x401E7000 part of the
>> > > workspace or
>> > > heap?
>> > > CU
>> > > Sebastian Huber, embedded brains GmbH
>> > > Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> > > Phone : +49 89 18 90 80 79-6
>> > > Fax : +49 89 18 90 80 79-9
>> > > E-Mail : sebastian.huber at embedded-brains.de
>> > > PGP : Public key available on request.
>> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>> > EHUG.
>> > _______________________________________________
>> > rtems-users mailing list
>> > http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D. Director of Research& Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
