On 12/15/2009 01:56 PM, Wolfram Wadepohl wrote: > What is the best RPM package to start with on Debian? > I want to use alien to get the RPM installed. If I were you, I'd give the CentOS5 built rpms a try. They are built against a pretty conservative set of libraries, which is likely to be compatible to most Linux distros. Ralf
